查看: 2560|回复: 3
sql注入数据库修复方法
发表于 2013-10-27 21:55:35 | 显示全部楼层 |阅读模式
1.第一种情况是 需要将指定的 注入字符串全部替换掉(仅替换注入的字符串为空)
declare @delStr nvarchar(500)
set @delStr='<script src=http://www.111cn.net/js/common.js></script>' --这里被注入的字段串
/**********以下为操作实体************/
set nocount on
declare @tableName nvarchar(100),@columnName nvarchar(100),@tbID int,@iRow int,@iResult int
declare @sql nvarchar(2000)
set @iResult=0
declare cur cursor for
select name,id from sysobjects where xtype='U'
open cur
fetch next from cur into @tableName,@tbID
while @@fetch_status=0
begin
declare cur1 cursor for
select name from syscolumns where xtype in (231,167,239,175, 35, 99) and id=@tbID
open cur1
fetch next from cur1 into @columnName
begin
set @sql='update [' + @tableName + '] set ['+ @columnName +']= SUBSTRING([' + @columnName + '],' + '1, PATINDEX( ''%' + @delStr + '%'', [' + @columnName + '])-1) + ' + 'SUBSTRING([' + @columnName + '], PATINDEX( ''%' + @delStr + '%'', [' + @columnName + ']) + ' + 'len(''' + @delStr + ''') , datalength([' + @columnName + '])) where ['+@columnName+'] like ''%'+@delStr+'%'''
exec sp_executesql @sql
set @iRow=@@rowcount
set @iResult=@iResult+@iRow
if @iRow>0
begin
print '表:'+@tableName+',列:'+@columnName+'被更新'+convert(varchar(10),@iRow)+'条记录;'
end
end
close cur1
deallocate cur1
end
print '数据库教程共有'+convert(varchar(10),@iResult)+'条记录被更新!!!'
close cur
deallocate cur
set nocount off
2.第二种是  需要将注入到表中起始位置到最后都删掉。(此种方法直接找到注入的起始位置,后面的全部删掉)
--恢复被注入数据库
--2013-09-26
set @delStr='</title><style>.' --被注入的字段串的开始采样,从此位置后面的数据都为注入数据
set nocount on
set @iResult=0
open cur
begin
open cur1
begin
SUBSTRING([' + @columnName + '],1, PATINDEX( ''%' + @delStr + '%'', [' + @columnName + '])-1)   where ['+@columnName+'] like ''%'+@delStr+'%'''
if @iRow>0
begin
end
end
close cur1
deallocate cur1
end
close cur
deallocate cur
set nocount off
发表于 2013-10-27 21:55:50 | 显示全部楼层
俺是专业顶贴滴~~~
发表于 2013-10-27 22:04:56 | 显示全部楼层
我是来刷分的,嘿嘿
li61393681 该用户已被删除
发表于 2013-11-23 22:42:31 | 显示全部楼层
表示什么都看不懂...
