查看: 2488|回复: 3
短信发送AZDG加密算法
发表于 2013-10-14 12:49:38 来自手机 | 显示全部楼层 |阅读模式
  public static string passport_encrypt(string txt, string key)
            //   使用随机数发生器产生   0~32000   的值并   MD5()
            Random rnd = new Random(100);
            int int_encrypt_key = rnd.Next(0, 32000);
            string encrypt_key = int_encrypt_key.ToString();
            int ctr = 0;
            string tmp = "";
            byte[] encodebyte = new byte[txt.Length];
            for (int i = 0; i < txt.Length; i++)
            ctr = ctr == encrypt_key.Length ? 0 : ctr;
            char prefix = encrypt_key[ctr];
            char left = txt[i];
            char right = encrypt_key[ctr++];
            encodebyte[i] = (byte)(left ^ right);
            char[] block = new char[2];
            block[0] = prefix;
            block[1] = Convert.ToChar(encodebyte[i]);
            tmp += new string(block);
            //////用base64编码
            string complicatedstring = passport_key(tmp, key);/////先和key加一次密?
            byte[] inputbytes = System.Text.Encoding.Default.GetBytes(complicatedstring);
            string string_64 = Convert.ToBase64String(inputbytes, 0, inputbytes.Length);/////再和随机key加密
            return string_64;
        public static string passport_decrypt(string txt, string key)
            byte[] array_64 = Convert.FromBase64String(txt);
            string txt_64 = System.Text.Encoding.Default.GetString(array_64);
            txt = passport_key(txt_64, key);
            string temp = "";
            char left = txt[i];
            char right = txt[++i];
            temp = System.Text.Encoding.Default.GetString(encodebyte);
            return temp;
发表于 2013-10-14 12:59:29 | 显示全部楼层
不错不错,楼主您辛苦了。。。
zeroday 该用户已被删除
发表于 2013-10-24 14:35:03 来自手机 | 显示全部楼层
潜水是一种美德,回帖是一种责任!见贴就回,捞金币就闪。专业水金币。-----雷锋蜀黍
