查看: 1067|回复: 2
代码审计–Dedecms最新版本存储xss
发表于 2013-10-8 21:21:43 来自手机 | 显示全部楼层 |阅读模式
由于编辑文章的模板参数 typeid2可控,导致存储xss发生。
dedecms/dede/templets/article_edit.htm页面316-325行代码如下:
  <tr>
      <td height="24" colspan="2" class="bline"><table width="800" border="0" cellspacing="0" cellpadding="0">
          <tr>
            <td width="90"> 文章副栏目:</td>
            <td><span id='typeid2ct'></span>
            <input type='text' name='typeid2' id='typeid2' value='<?php echo ($arcRow['typeid2']=='0' ? '' : $arcRow['typeid2']); ?>' style='width:200px;' />
            <img src='images/menusearch2.gif' style='cursor:pointer;' onClick="ShowCatMap(event, this, <?php echo $channelid; ?>, 'typeid2', '<?php echo $arcRow['typeid2']; ?>')" alt='选择副栏目' title='选择副栏目' /></td>
          </tr>
        </table></td>
    </tr>
从上面可以看出,变量$channelid 与 $arcRow['typeid2'] 只要可控,就可以造成XSS,接下来我们去找找能控制$channelid和$arcRow['typeid2']的页面。
dedecms/dede/catalog_do.php页面249-310行代码如下:
else if($dopost == 'unitCatalog')
    CheckPurview('t_Move');
    require_once(DEDEINC.'/oxwindow.class.php');
    require_once(DEDEINC.'/typelink.class.php');
    require_once(DEDEINC.'/channelunit.func.php');
    if(empty($nextjob))
        $typeid = isset($typeid) ? intval($typeid) : 0;
        $row = $dsql->GetOne("SELECT COUNT(*) AS dd FROM `#@__arctype` WHERE reid='$typeid' ");
        $tl = new TypeLink($typeid);
        $typename = $tl->TypeInfos['typename'];
        $reid = $tl->TypeInfos['reid'];
        $channelid = $tl->TypeInfos['channeltype'];
        if(!empty($row['dd']))
            ShowMsg("栏目: $typename($typeid) 有子栏目,不能进行合并操作!", '-1');
            exit();
        $typeOptions = $tl->GetOptionArray(0, 0, $channelid);
        $wintitle = '合并栏目';
        $wecome_info = "<a href='catalog_main.php'>栏目管理</a> >> 合并栏目";
        $win = new OxWindow();
        $win->Init('catalog_do.php', 'js/blank.js', 'POST');
        $win->AddHidden('dopost', 'unitCatalog');
        $win->AddHidden('typeid', $typeid);
        $win->AddHidden('channelid', $channelid);
        $win->AddHidden('nextjob', 'unitok');
        $win->AddTitle("合并目录时不会删除原来的栏目目录,合并后需手动更新目标栏目的文档HTML和列表HTML。");
        $win->AddItem('你选择的栏目是:', "<font color='red'>$typename($typeid)</font>");
        $win->AddItem('你希望合并到那个栏目?', "<select name='unittype'>\r\n{$typeOptions}\r\n</select>");
        $win->AddItem('注意事项:', '栏目不能有下级子栏目,只允许子级到更高级或同级或不同父级的情况。');
        $winform = $win->GetWindow('ok');
        $win->Display();
        exit();
    else
        if($typeid==$unittype)
            ShowMsg("同一栏目无法合并,请后退重试!", '-1');
            exit();
        if(IsParent($unittype, $typeid))
            ShowMsg('不能从父类合并到子类!', 'catalog_main.php');
            exit();
        $row = $dsql->GetOne("SELECT addtable FROM `#@__channeltype` WHERE id='$channelid' ");
        $addtable = (empty($row['addtable']) ? '#@__addonarticle' : $row['addtable'] );
        $dsql->ExecuteNoneQuery("UPDATE `#@__arctiny` SET typeid='$unittype' WHERE typeid='$typeid' ");
        $dsql->ExecuteNoneQuery("UPDATE `#@__feedback` SET typeid='$unittype' WHERE typeid='$typeid' ");
        $dsql->ExecuteNoneQuery("UPDATE `#@__archives` SET typeid='$unittype' WHERE typeid='$typeid' ");
        $dsql->ExecuteNoneQuery("UPDATE `#@__archives` SET typeid2='$unittype' WHERE typeid2='$typeid' ");
        $dsql->ExecuteNoneQuery("UPDATE `#@__addonspec` SET typeid='$unittype' WHERE typeid='$typeid' ");
        $dsql->ExecuteNoneQuery("UPDATE `$addtable` SET typeid='$unittype' WHERE typeid='$typeid' ");
        $dsql->ExecuteNoneQuery("DELETE FROM `#@__arctype` WHERE id='$typeid' ");
        UpDateCatCache();
        ShowMsg('成功合并指定栏目!', 'catalog_main.php');
        exit();
由于变量$channelid 在该文件头部已经被过滤为intval($channelid),所以这个变量利用不了。
弱点代码在这里
$dsql->ExecuteNoneQuery(“UPDATE `#@__archives` SET typeid2=’$unittype’ WHERE typeid2=’$typeid’ “);
只要我们构造好POC,即可修改dede_archives表typeid2的值,从而造成存储XSS,因为编辑文章的时候,typeid2的值已经在数据库改了,所以每次编辑文章即可触发这个恶意代码。
也就是说当提交
URLpostdata:dopost=unitCatalog&nextjob='非空值'&typeid=0&unittype='><img src="x" onerror="alert(1)">
下面这个sql语句就会执行成功
当然执行这条sql语句前提是这个表里的一定要有1条记录
利用方法就是CSRF 让管理员请求这个构造好的URL即可
发表于 2013-10-8 21:31:03 | 显示全部楼层
没看完~~~~~~ 先顶,好同志
发表于 2013-10-8 21:48:46 | 显示全部楼层
没看完~~~~~~ 先顶,好同志
