查看: 2120|回复: 0
mimipenguin-类似于Mimikatz的Linux Hash Dump工具
发表于 2017-4-4 21:47:16 | 显示全部楼层 |阅读模式
mimipenguin
A tool to dump the login password from the current linux desktop user. Adapted from the idea behind the popular Windows tool mimikatz.
  • Special thanks to pugilist for cleaning up PID extraction and testing.
Details
Takes advantage of cleartext credentials in memory by dumping the process and extracting lines that have a high probability of containing cleartext passwords. Will attempt to calculate each word's probability by checking hashes in /etc/shadow, hashes in memory, and regex searches.
Requires
  • root permissions
Supported/Tested
  • Kali 4.3.0 (rolling) x64 (gdm3)
  • Ubuntu Desktop 12.04 LTS x64 (Gnome Keyring 3.18.3-0ubuntu2)
  • Ubuntu Desktop 16.04 LTS x64 (Gnome Keyring 3.18.3-0ubuntu2)
  • XUbuntu Desktop 16.04 x64 (Gnome Keyring 3.18.3-0ubuntu2)
  • VSFTPd 3.0.3-8+b1 (Active FTP client connections)
  • Apache2 2.4.25-3 (Active/Old HTTP BASIC AUTH Sessions)
  • openssh-server 1:7.3p1-1 (Active SSH connections - sudo usage)
Notes
  • Password moves in memory - still honing in on 100% effectiveness
  • Plan on expanding support and other credential locations
  • Working on expanding to non-desktop environments
  • Known bug - sometimes gcore hangs the script, this is a problem with gcore
  • Open to pull requests and community research
  • LDAP research (nscld winbind etc) planned for future
ContactLicence
https://github.com/huntergregal/mimipenguin
