查看: 2456|回复: 0
Sqlmap的sqlmapapi.py简单使用
发表于 2015-8-18 20:35:48 | 显示全部楼层 |阅读模式
一.启动服务器
  1. $ python sqlmapapi.py -s -H 0.0.0.0
  2. [19:42:00] [INFO] Running REST-JSON API server at '0.0.0.0:8775'..
  3. [19:42:00] [INFO] Admin ID: cfdd0c84a8ebbccf40a97fe6eaaeac9d
  4. [19:42:00] [DEBUG] IPC database: /tmp/sqlmapipc-QUdQ7m
  5. [19:42:00] [DEBUG] REST-JSON API server connected to IPC database
服务器后端使用的是bottle,一个Python Web微框架。
二. 我们使用requests这个库发送请求
        1.新建任务
        2.发送扫描选项,开启扫描
        注意:那个cd92e4e99406715b就是新建任务返回的taskid
      3.查看扫描状态
        任务已经结束,可以获取扫描结果了
      4.查看扫描结果
  1. $ curl http://127.0.0.1:8775/task/new
  2. {
  3.   "taskid": "4be40bb5e98a03c2",
  4.   "success": true
  5. }
  6. $ curl -H "Content-Type: application/json" -X POST -d '{"url": "http://testphp.vulnweb.com/artists.php?artist=1"}' http://127.0.0.1:8775/scan/4be40bb5e98a03c2/start
  7. {
  8.   "engineid": 3068,
  9.   "success": true
  10. }
  11. $ curl http://127.0.0.1:8775/scan/4be40bb5e98a03c2/data
  12. {
  13.   "data": [],
  14.   "success": true,
  15.   "error": []
  16. }
  17. $ curl http://127.0.0.1:8775/scan/4be40bb5e98a03c2/log
  18. {
  19.   "log": [
  20.     {
  21.       "message": "testing connection to the target URL",
  22.       "level": "INFO",
  23.       "time": "19:44:23"
  24.     },
  25.     {
  26.       "message": "testing if the target URL is stable. This can take a couple of seconds",
  27.       "level": "INFO",
  28.       "time": "19:44:24"
  29.     },
  30.     {
  31.       "message": "target URL is stable",
  32.       "level": "INFO",
  33.       "time": "19:44:25"
  34.     },
  35.     {
  36.       "message": "testing if GET parameter 'artist' is dynamic",
  37.       "level": "INFO",
  38.       "time": "19:44:25"
  39.     },
  40.     {
  41.       "message": "confirming that GET parameter 'artist' is dynamic",
  42.       "level": "INFO",
  43.       "time": "19:44:25"
  44.     },
  45.     {
  46.       "message": "GET parameter 'artist' is dynamic",
  47.       "level": "INFO",
  48.       "time": "19:44:26"
  49.     },
  50.     {
  51.       "message": "heuristic (basic) test shows that GET parameter 'artist' might be injectable (possible DBMS: 'MySQL')",
  52.       "level": "INFO",
  53.       "time": "19:44:26"
  54.     },
  55.     {
  56.       "message": "testing for SQL injection on GET parameter 'artist'",
  57.       "level": "INFO",
  58.       "time": "19:44:26"
  59.     },
  60.     {
  61.       "message": "testing 'AND boolean-based blind - WHERE or HAVING clause'",
  62.       "level": "INFO",
  63.       "time": "19:44:26"
  64.     },
  65.     {
  66.       "message": "GET parameter 'artist' seems to be 'AND boolean-based blind - WHERE or HAVING clause' injectable ",
  67.       "level": "INFO",
  68.       "time": "19:44:27"
  69.     },
  70.     {
  71.       "message": "testing 'MySQL >= 5.0 AND error-based - WHERE or HAVING clause'",
  72.       "level": "INFO",
  73.       "time": "19:44:27"
  74.     },
  75.     {
  76.       "message": "testing 'MySQL >= 5.1 AND error-based - WHERE or HAVING clause (EXTRACTVALUE)'",
  77.       "level": "INFO",
  78.       "time": "19:44:27"
  79.     },
  80.     {
  81.       "message": "testing 'MySQL >= 5.1 AND error-based - WHERE or HAVING clause (UPDATEXML)'",
  82.       "level": "INFO",
  83.       "time": "19:44:28"
  84.     },
  85.     {
  86.       "message": "testing 'MySQL >= 4.1 AND error-based - WHERE or HAVING clause'",
  87.       "level": "INFO",
  88.       "time": "19:44:28"
  89.     },
  90.     {
  91.       "message": "testing 'MySQL >= 5.0 OR error-based - WHERE or HAVING clause'",
  92.       "level": "INFO",
  93.       "time": "19:44:28"
  94.     },
  95.     {
  96.       "message": "testing 'MySQL >= 5.1 OR error-based - WHERE or HAVING clause (EXTRACTVALUE)'",
  97.       "level": "INFO",
  98.       "time": "19:44:29"
  99.     },
  100.     {
  101.       "message": "testing 'MySQL >= 5.1 OR error-based - WHERE or HAVING clause (UPDATEXML)'",
  102.       "level": "INFO",
  103.       "time": "19:44:29"
  104.     },
  105.     {
  106.       "message": "testing 'MySQL >= 4.1 OR error-based - WHERE or HAVING clause'",
  107.       "level": "INFO",
  108.       "time": "19:44:29"
  109.     },
  110.     {
  111.       "message": "testing 'MySQL OR error-based - WHERE or HAVING clause'",
  112.       "level": "INFO",
  113.       "time": "19:44:29"
  114.     },
  115.     {
  116.       "message": "testing 'MySQL >= 5.0 error-based - Parameter replace'",
  117.       "level": "INFO",
  118.       "time": "19:44:30"
  119.     },
  120.     {
  121.       "message": "testing 'MySQL >= 5.1 error-based - Parameter replace (EXTRACTVALUE)'",
  122.       "level": "INFO",
  123.       "time": "19:44:30"
  124.     },
  125.     {
  126.       "message": "testing 'MySQL >= 5.1 error-based - Parameter replace (UPDATEXML)'",
  127.       "level": "INFO",
  128.       "time": "19:44:30"
  129.     },
  130.     {
  131.       "message": "testing 'MySQL inline queries'",
  132.       "level": "INFO",
  133.       "time": "19:44:30"
  134.     },
  135.     {
  136.       "message": "testing 'MySQL > 5.0.11 stacked queries'",
  137.       "level": "INFO",
  138.       "time": "19:44:31"
  139.     },
  140.     {
  141.       "message": "testing 'MySQL < 5.0.12 stacked queries (heavy query)'",
  142.       "level": "INFO",
  143.       "time": "19:44:31"
  144.     },
  145.     {
  146.       "message": "testing 'MySQL > 5.0.11 AND time-based blind'",
  147.       "level": "INFO",
  148.       "time": "19:44:31"
  149.     },
  150.     {
  151.       "message": "GET parameter 'artist' seems to be 'MySQL > 5.0.11 AND time-based blind' injectable ",
  152.       "level": "INFO",
  153.       "time": "19:44:42"
  154.     },
  155.     {
  156.       "message": "testing 'MySQL UNION query (NULL) - 1 to 20 columns'",
  157.       "level": "INFO",
  158.       "time": "19:44:42"
  159.     },
  160.     {
  161.       "message": "automatically extending ranges for UNION query injection technique tests as there is at least one other (potential) technique found",
  162.       "level": "INFO",
  163.       "time": "19:44:42"
  164.     },
  165.     {
  166.       "message": "ORDER BY technique seems to be usable. This should reduce the time needed to find the right number of query columns. Automatically extending the range for current UNION query injection technique test",
  167.       "level": "INFO",
  168.       "time": "19:44:42"
  169.     },
  170.     {
  171.       "message": "target URL appears to have 3 columns in query",
  172.       "level": "INFO",
  173.       "time": "19:44:43"
  174.     },
  175.     {
  176.       "message": "GET parameter 'artist' is 'MySQL UNION query (NULL) - 1 to 20 columns' injectable",
  177.       "level": "INFO",
  178.       "time": "19:44:44"
  179.     },
  180.     {
  181.       "message": "the back-end DBMS is MySQL",
  182.       "level": "INFO",
  183.       "time": "19:44:45"
  184.     }
  185.   ],
  186.   "success": true
  187. }
