查看: 1183|回复: 0
The Social-Engineer Toolkit V6.0发布
发表于 2014-5-31 17:11:18 | 显示全部楼层 |阅读模式
社会工程学工具集Social-Engineer Toolkit (SET) v6.0发布。Social Engineering Toolkit (SET)是一个开源、Python驱动的社会工程学渗透测试工具,提供了非常丰富的攻击向量库。
6.0版本修复了多个BUG,详情如下:
* fixed psexec which would only bring one shell back instead of as many as you used for the host* fixed an issue that would cause metasploit payloads to not be properly generated when using msfvenom, this was due to a code change requiring -f * on the update SET menu, it will automatically check if Kali Linux is installed, if it is will automatically enable bleeding edge repos for daily updates to SET* added SET to automatically do apt-get update/upgrade/dist-upgrade/autoremove upon checking for updates if using Kali* fixed an issue that would cause the MSsql bruter to throw a payload_options error when powershell was detected, this was due to a file not being written out for payloads.powershell.prep to function properly* updated dell drac attack to remove old working and twitter handle* upgraded downgrade attack for powershell to server 2008/2012 compatiblity* fixed a sql port bug error that would cause the mssql bruter to fail when importing a list without a port* fixed an issue in sql bruter when legacy debug method was used if no powershell, would error out when selecting a standard Metasploit payload* fixed an issue that was causing a menu mismatch using the web attack vector, when selecting anything above 5 would cause a menu mismtach* fixed dr4k0s menu system so when you 99 out, it goes back to the SET menus by returning at that point versus exit(0)* removed NAT and cloner from dr4k0s fsattack – it was automatically added based on attack vector, wasn’t needed* added additional fixes for msfvenom and generating https/http shells* fixed an issue that would cause webjacking method to not successfully redirect to index2.html when use APACHE_SERVER=ON* made apache_server=on to the default – still configurable in config/set_config* fixed a bug that would cause mssql deploy stager on legacy debug64 to throw an error on not finding 1msf.exe – this has since been resolved* removed old references to a module that is no longer in SET* updated the SET user manual to the latest version 6.0 and incorporated the FSAttack from d4rk0s* added ablity for OSX persistence when you have access to the filesystem* permenantly removed the command center, will redesign later – no longer needed* removed command center wording from SET user manual* removed command center options in the set_config* removed unused options inside set_config related to mlitm* added automatic check to see if bleeding edge repos were enabled or not when using Kali – if kali is in use will prompt to automatically enable bleeding edge repos* updated seupdate to reflect bleeding edge repos as well* removed self_signed_applet from the config menu – it will not prompt inside of the Java Applet Attack method* added ability to use same codebase for the new selection process for SET.* redesigned the java applet selection process and allow you to verify new code signign certificates or import your own applet into the java applet attack method* added better error handlign when using setoolkit* updated the version of RIDENUM to the latest version inside of SET* updated the report template to remove secmaniac and update with trustedsec* removed old references to secmaniac in various code segments* added the MS14-012 Microsoft Internet Explorer CMarkup Use-After-Free from Metasploit* added the MS14-012 Microsoft Internet Explorer TextRange Use-After-Free exploit from Metasploit* added the MS14-017 Microsoft Word RTF Object Confusion fileformat exploit* added a new initial image loader (doctor who theme) – pssssh* removed the metasploit update feature – this should be handled through kali and theres packages, distributions, etc. its hard to predict which will be used for Metasploit* removed old mentions in update_config that were no longer needed* removed the sms attack vector – it hasn’t been maintained or updated in a long time and no longer supported* added option 99 in qrcode generation to go back a previous menu, it was missing* added set ExitOnSession for autorun attack inside of SET* changed some of the formating and variable names in the fsattack
下载地址github
