查看: 7516|回复: 11
社会工程学攻击包(SET)
发表于 2013-9-2 16:42:58 | 显示全部楼层 |阅读模式
Social Engineering Toolkit (SET)是一个开源、Python驱动的社会工程学渗透测试工具,提供了非常丰富的攻击向量库。
该版本的SET可植入多种powershel并进行任意端口的转发,同时SET不会触及硬盘且使用已经进入白名单的进程,因此不会触发杀毒软件的报警。
主要更新记录:
removed a prompt that would come up when using the powershell injection technique, port.options is now written in prep.py versus a second prompt with information that was already provided
began an extremely large project of centralizing the SET config file by moving all of the options to the set.options file under src/program_junk
moved all port.options to the central routine file set.options
moved all ipaddr.file to the central routine file set.options
changed spacing on when launching the SET web server
changed the wording to reflect what operating systems this was tested on versus browsers
removed an un-needed print option1 within smtp_web that was reflecting a message back to user
下载命令
游客,如果您要查看本帖隐藏内容请回复
发表于 2013-9-2 16:45:38 | 显示全部楼层
我是来刷分的,嘿嘿
发表于 2013-9-2 16:51:39 | 显示全部楼层
路过,学习下
尐徫 该用户已被删除
发表于 2013-9-14 13:18:17 | 显示全部楼层
只是过来看看
阿斯顿 该用户已被删除
发表于 2013-10-6 09:46:14 | 显示全部楼层
谢谢你啊,我想学学看去
